inside of car fogging up...
Old Sep 12, 2006 | 05:21 PM
dohc_profile's Avatar
Default inside of car fogging up...
hey guys friend has a hatch. its normal for the car to fog when its raining, but his is really bad, and even tho the heaters are on, difficult to get rid of. any suggestions as to why this is happening? or any solutions. TIA
Old Sep 12, 2006 | 05:23 PM
4DRmafia's Avatar
i just use the a/c?
Old Sep 12, 2006 | 05:24 PM
if only he had a/c lol. i basically told him hes SOL. dont drive when there humidity or turn on ur fan and deal wiht it lol
Old Sep 12, 2006 | 05:25 PM
4DRmafia's Avatar
well a/c only works well or clean ur windows with newpaper and some window cleaner ...
Miracle's Avatar
Default Re: (SkipMic2006)
Rain-X makes an awesome anti-fog for cars. Kinda like the rain-x exterior window treatment. You can get it at pretty much any parts store.
I put it in my EM2, and rarely ever have an issue with cloudiness on the windows on the inside.
Old Sep 12, 2006 | 05:27 PM
4DRmafia's Avatar
yea.. i used rain-x once and it seem like it didnt work for me ?
Old Sep 12, 2006 | 05:32 PM
Miracle's Avatar
How did you put it on? Because if you don't do it a certain way, it really is not that effective.
Old Sep 12, 2006 | 05:43 PM
4DRmafia's Avatar
idk i just wipe it all down ?
Old Sep 12, 2006 | 05:49 PM
Miracle's Avatar
This is what worked for me...
Take a soft terry cloth or microfiber cloth, spray some of the chemical on the cloth, and wipe down the inside of the windshield with the Anti-Fog.
Make a small circular, overlapping pattern, with moderate pressure. After that, just get a clean side of the towel, or a new towel, and wipe the excess off after letting it sit for a bit.
Old Sep 12, 2006 | 05:54 PM
leeminho86's Avatar
Default Re: inside of car fogging up... (dseries_ef)
I know how he feels, I have a gutted hatch so it seems like it fogs up isntantaneously...but using the heater works for me. Has he put it on blast and made sure air is actually coming out? If he has debris or whatever else that is blocking the vents that could be part of the problem.
Old Sep 12, 2006 | 05:58 PM
96dxpower's Avatar
you can get some rain visors and crack the window open. just an option.
Old Sep 12, 2006 | 06:00 PM
tommy.'s Avatar
i used that rain x stuff on my car and it worked pretty good. but after a while. the inside of the window got dirty =P
Old Sep 12, 2006 | 06:04 PM
jdmeg9's Avatar
it's a honda. they make sure at the factory that it will fog up everytime
Old Sep 12, 2006 | 06:13 PM
old man neri's Avatar
1) heat on with engine warm
2) window cracked open
Cheers.
Old Sep 12, 2006 | 06:16 PM
ok thanks for all the help guys. def pass this info on. thanks again
Old Sep 13, 2006 | 02:42 AM
jdmeg9's Avatar
Default Re: (old man neri)
i always have the mexican air conditioner running when i am driving
Old Sep 13, 2006 | 03:30 AM
Syndacate's Avatar
Okay, I don't want to go into the whole chemistry lesson now, but I'm make it real brief. If it's just plain cold as **** outside - but it's DRY, then use your defoggers/defrosters. If it's fogging up on the inside and it's cool or cold & WET then use the COLD air vents directed towards the windshield (defoggers on cold instead of warm) and crack a window a bit. Once the ambient temperature in your car matches the one outside your windows won't fog. This of course is made harder by the fact that it's wet outside. If you put the front defoggers on (maybe cold is a bad example, say a scale from 1-10, 1 being hot, ten being cold, put it on like 6 or 7 or 8). You do that, and the windows will defog very quickly...but if you shut the window and turn the defogger off, they'll fog back up hella quickly.
Take it from me, we get a lot of rain in NY. Maybe not as much as Hawaii, but enough to know that hot air doesn't work when it's wet outside, have to use cold. AC preferably, but I don't have AC in my civic (as you said you don't) so the "cold" vents will work just as well (or almost ).
Hope that helps.
Old Sep 13, 2006 | 07:26 AM
4thgenx42's Avatar
PLAIN AND SIMPLE KEEP YOUR WINDOWS CLEAN
Old Sep 13, 2006 | 07:36 AM
jiggatone's Avatar
vent visors.
fog free
Old Sep 13, 2006 | 07:54 AM
ffHeart's Avatar
Another reason it will fog up is if he has the heat on recirculate. If he has the outside air switch on, it will help prevent fog from forming in the first place.
Old Sep 13, 2006 | 09:52 AM
Sleepy_Red_hatch's Avatar
Default Re: inside of car fogging up... (ffHeart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ffHeart &raquo;</TD></TR><TR><TD CLASS="quote">Another reason it will fog up is if he has the heat on recirculate. If he has the outside air switch on, it will help prevent fog from forming in the first place. </TD></TR></TABLE>
lol beat me to it
Old Sep 13, 2006 | 10:01 AM
SHG_Beans's Avatar
The rainx anti fog someone had mentioned earlier is good stuff, but like he said if applied correctly. Read the box, and it works. Personally i dont have much of a problem with fog, Keep the vents on fresh and when it fogs up i put it right between hot/cold. No a/c in my car. Keeping the windows cracked is great. I just need some visors.
Old Sep 13, 2006 | 10:26 AM
ddd4114's Avatar
Default Re: (.Red.EM2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Red.EM2 &raquo;</TD></TR><TR><TD CLASS="quote">Rain-X makes an awesome anti-fog for cars.</TD></TR></TABLE>
Old Sep 13, 2006 | 10:30 AM
EKDreamin's Avatar
Default Re: (4thgenx42)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4thgenx42 &raquo;</TD></TR><TR><TD CLASS="quote">PLAIN AND SIMPLE KEEP YOUR WINDOWS CLEAN</TD></TR></TABLE>
Old Sep 15, 2006 | 09:57 AM
ekc9's Avatar
If its really a big problem like all tha time then check your heater core or maybe its ur evaporator( at tha fire wall underdash)......
JDMJUNKIEMONKIE
15
Nov 6, 2009 06:16 PM
user 98292739
29
Oct 30, 2005 09:07 PM
kX
Jul 9, 2005 02:51 PM
m0dr0cker
16
Oct 21, 2003 09:55 AM
darkvibe
10
Jul 14, 2003 03:01 PM
