JDM B16A2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92redhatch »</TD></TR><TR><TD CLASS="quote">b16b and b18c1 = same block. Look at any b16b block i bet it says p72.</TD></TR></TABLE>
Wouldn't it be the same as ITR? I thought the CTR was a destroked ITR?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">P72 and PR3 are head cast numbers, and will not be on the block.</TD></TR></TABLE>
I know for a fact my USDM C1 block has P72 stamped it. I saw it with my own eyes just recently
ya and ive seen for my own eyes a b16b block and on the bottom it was stamped p72 and it was exactly the same as a gsr block i had. Ive taken apart a itr motor before but i didnt checck and see if it said p72. it should though because its the same block as a gsr.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadEnd9009 »</TD></TR><TR><TD CLASS="quote">so i can take my B16A3 and stick a b18 crank and rods and it'll be a b18?</TD></TR></TABLE>
Nope, you will have a messed up head.
This is a funny thread. ITR and CTR's use the same engine blocks. THe diference is in their stroke distance. THe CTR's pistons travel less, thus making the engine a 1.6L.
Correct me if I am wrong but this is how I allways though things worked.
B16b, B18c1-5 = 1.8 block regardless. only difference is stroke, and head. B16b is a ITR motor but with 1.6 internals hense B16b, and not B18.
you can't make a 1.6 into a 1.8 without changing the bore, and stroke.
Alright, here's my humble opinion..
First off, scratch the CTR or any branches using that motor, it costs way too much and doesn't have enough torque due to the low *** stroke, better motor IMO than the ITR for boosting....if you're not boosting, I'd say ITR > CTR...but that's just me.
Now I think what you mean by "type-R conversion" is when somebody buys a B16a or GSR motor and puts ITR cam shafts, valve train, pistons & rods int here - it's also known sometimes as the "poor man's type R." It's usually done with a GSR, but I'm sure somebody's pulled it off with a 99/00 si motor.
I suppose in the name of all that's interchangable you can put CTR stuff in there instead but why pay just as much (if not more) for parts that won't up the ante on your engine as much?
Hope that helps.
Hope that helps.
