I need help identifying these rims
Old Sep 12, 2006 | 04:14 PM
chahsiubow's Avatar
Default I need help identifying these rims
I picked up a set of these for free off of freecyle. Anyone know if this will fit my integra perfectly?
From what I can tell, they are most likely somewhere between an 81-87 Audi 4000 rim.
Judging from this chart, it should be a perfect fit for my integra. http://www.discountedwheelware...e.cfm
Here's a list of other rims for that model:
http://www.wheelcollision.com/audi2.htm
Can anyone verify that I'm correct? Or can identify these rims? I want to make sure they fit before I clean them off and rip off the crappy tires on them. I'm planning to use them as my snow tire rims if they fit.
Thanks wheel gods!
Old Sep 12, 2006 | 04:20 PM
t0p_sh0tta's Avatar
Default Re: I need help identifying these rims (chahsiubow)
Check the rear for offset and bolt pattern. It's usually stamped on there somewhere.
Old Sep 12, 2006 | 04:23 PM
chahsiubow's Avatar
Default Re: I need help identifying these rims (t0p_sh0tta)
They're packed with some thick mud in the back (from being left out for a long time), and I didn't get a chance to clean them. Just curious if anyone could eyeball them offhand.
Old Sep 13, 2006 | 11:50 AM
crxma22's Avatar
i could be wrong but they look like oem rims off an older acura legend...
Old Sep 13, 2006 | 01:59 PM
Leo C's Avatar
Night Owl
Most older Audi's use a 4x120mm bolt pattern. In 1/10 of the time it took to take that pic, host it, and make this post, you could have simply measured the bolt pattern and seen for yourself. Common sense> ht.
Old Sep 13, 2006 | 04:14 PM
chahsiubow's Avatar
Default Re: I need help identifying these rims (shutupnskate)
I pulled that pic straight off of a wheel site.
I pulled the center cap and the numbers listed are:
6Jx14H2
ET45
8116010250
From googling, one other person on some random message board has the same long digit number with a 4x100. And from what I can gather, from 1985 and on, the Audis went the 4x108 pattern.
Old Sep 13, 2006 | 04:46 PM
Leo C's Avatar
Night Owl
Quit debating about the wheel, go grab a tape measure, and measure the space between the lugs pattern. /thread
Old Sep 13, 2006 | 05:18 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shutupnskate &raquo;</TD></TR><TR><TD CLASS="quote">Quit debating about the wheel, go grab a tape measure, and measure the space between the lugs pattern. /thread
Agreed, though hub size could matter as well, if they were originally intended to be hub centric wheels and if the Audi has a smaller hub.
pr_boricua9
Suspension & Brakes
13
Sep 29, 2016 09:45 AM
1991hb
Classic Hondas
Jul 21, 2007 06:26 PM
DeDonDeRosa
Nov 26, 2002 11:44 AM
