help asap
Old Sep 12, 2006 | 12:42 PM
pompom's Avatar
Default help asap
my civic has a jdm b16a and i need to get some things for it to pass emissions, so i need to know what is the jdm b16a equivalent to in the states and what car is it in? my best guess is a 94 del sol vtec...can anyone help me out?i need to know asap...
Old Sep 12, 2006 | 12:48 PM
MattsGreenEG's Avatar
Default Re: help asap (pompom)
help the man out
Old Sep 12, 2006 | 01:22 PM
frmFL2VA's Avatar
yo i belive its in the usdm ek si good luck man emissions can sometimes be a nightmare when a swap is envolved
Old Sep 12, 2006 | 01:37 PM
pompom's Avatar
Default Re: help asap (frmFL2VA)
can anyone confirm?99-00 si is what i was leanin towards...
Old Sep 12, 2006 | 01:50 PM
JDM-EJ1's Avatar
The 99-00 Si Civic is OBD2 which means it uses two o2 sensors. Regarding the b16a which was in the EG chassi that was OBD1 I would say the motor you have is OBD1 which would only require one o2 sensor. I could be wrong though.
Old Sep 12, 2006 | 01:59 PM
pompom's Avatar
Default Re: help asap (JDM-EJ1)
i took it to some place and told them it was the same motor as the del sol and they said i need two. i welded the cat on last week and i think it was from the d-series that was origionally in it. what can i do to fix this problem? there is a hole in the cat that i beleive the o2 sensor goes into..helppp
Old Sep 12, 2006 | 02:02 PM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pompom &raquo;</TD></TR><TR><TD CLASS="quote">i took it to some place and told them it was the same motor as the del sol and they said i need two. i welded the cat on last week and i think it was from the d-series that was origionally in it. what can i do to fix this problem? there is a hole in the cat that i beleive the o2 sensor goes into..helppp</TD></TR></TABLE>
Just because you have a slot in your cat for an o2 sensor, doesn't mean you need one. Is the wiring on your car OBD1 or OBD2?
Old Sep 12, 2006 | 02:12 PM
pompom's Avatar
its in a 91 civic. how can i find out what wiring it is?
Civic Racer X 7
14
May 1, 2011 09:55 AM
namewasdallas
Mar 29, 2010 07:41 PM
Mohsin
16
Dec 28, 2007 09:04 AM
Moses154
Oct 7, 2007 09:55 AM
