jdm Sir crx front clip swap on EF civic
yes... but you have to cut the bottom off the civic fender and weld it to the bottom of the crx fender.... because the crx runs the filler panel i did the swap on my ef civic i welded it up under the molding so no body work would have to be done... u also have to run the crx corner lights
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integra_gs »</TD></TR><TR><TD CLASS="quote">why weld.. just use the same fenders to the front end.. </TD></TR></TABLE>
this is why you have to weld.
civic hatch
crx
as you can see they're very different,,lower portions,moldings,shape,wheel arch,corner lights...So to make this **** look good you weld the civic lower portion to the crx fender when swapping a crx front and a hatch,,and vice versa if you swap the hatch front on the crx..
can make it look like this..as you can see the top is a crx fender,,and the lower is a civic fender..
civic hatch
crx
balistic CRX
10
Feb 20, 2002 02:56 PM
