H22 with h23 head
Old Sep 12, 2006 | 09:02 AM
eagleclawracing's Avatar
Default H22 with h23 head
I just picked up an H23 with h22 head.... I think the Rod bearing is about to spin... how hard is that to replace... can i do it my self or i would have to send it off
Old Sep 12, 2006 | 09:14 AM
MadCityLude
Guest
Posts: n/a
Default Re: H22 with h23 head (eagleclawracing)
Say what? Why do you think the rod bearing is "about to spin"?
That isn't something you can usually predict.
Rod bearings are no all that hard to replace, but it is a very delicate job. You must be capable and have the equipment to take some very precise and critical measurements!
Old Sep 12, 2006 | 09:38 AM
shutta's Avatar
h22 w/ an h23 head? never heard of anyone doing that. usually it's an h23 with an h22 head..
Old Sep 12, 2006 | 09:53 AM
Default Re: (shutta)
its a typo Its an h23 h22 head sorry school has me stressed out lol
Old Sep 12, 2006 | 10:38 AM
eeleaj's Avatar
Default Re: (eagleclawracing)
if your rod bearings are going bad you will hear a ticking noise coming from the block, which means that your crank is being shaved. reason for that is because whoever built the block didnt position the body oil jets right or didnt put them in at all seeing as you have to literally bent the tubes to make it fit in the block. so you have to let us know if it is ticking at all. also as someone stated before you wont know if it is bad until it goes bad.
Loserkidwac
Mar 30, 2009 07:40 AM
pkolaboy
Feb 19, 2008 06:37 PM
DLB1994
Sep 23, 2001 07:26 PM
