Do I need to reinstall this piece? *pic*
Its the rear piece that goes behind the seats.
I just wanted to know if I can leave it out, and still bolt up my seats and center piece just fine.
if i remember correctly you need that piece in there for the seats to mount on. I could be wrong its been months since i played with my back seats. can anyone else verify?
i think you need it for seats... but if you dont want seats..then toss it.
only thing is.. i would wonder what that would do for structural rigidity.. it is called a crossmember for that matter
you dont need it for the seats but it used to stiff the frame a lil bit so i don't thing you should remove it, maybe you can replace it with some kind of better looking stiffer aftermarket bar.
this bar is where the 4WS ecu is mounted too (if you have a 4WS lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmmtrbolude93 »</TD></TR><TR><TD CLASS="quote">structural rigidity.. it is called a crossmember for that matter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99LudeDude »</TD></TR><TR><TD CLASS="quote">DO NOT THROW IT AWAY!!!!! I've read something a while ago on this crossmember being removed and the results were not what you would call desireable, if I remember right. I say leave it.</TD></TR></TABLE>
lol.. can you show us this post. I've had mine out for years going on 5 now. I never noticed a difference with it out or in the car.. it might keep the frame some what stiff. but in all actuality why don't you just buy a rear aftermarket cross member support if your want a stiffer frame. you don't need it.
the ones in my 93 accord didnt have much to them, i could bend them over my knee, so if they bend under maybe 100 lbs of pressure from me, i dont think theyre doing much with the 1000s of lbs of stress on the body....
overinflating the tires by 1 psi will make handling worse than leaving those out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twistedbydezign »</TD></TR><TR><TD CLASS="quote">the ones in my 93 accord didnt have much to them, i could bend them over my knee, so if they bend under maybe 100 lbs of pressure from me, i dont think theyre doing much with the 1000s of lbs of stress on the body....
overinflating the tires by 1 psi will make handling worse than leaving those out</TD></TR></TABLE>
you can pretty much say the same for the entire car's body panels if you cut them apart piece by piece, but as a whole assembly, i'd like to see you bend a car on your knee.
Guest
Posts: n/a
Now I am not saying that this piece is needed for sure but,
you would be surprised at how much strength could be lost in a chassis from one piece that size.
Sometimes the smallest of things can play a big role in structural integrity. Think about it. When it comes to structural design of thinks such as cars or buildings or whatever small things like that Can or Could make a huge differense in the strength of the chassis.
One of the above posters said he had been driving without his for 5 yrs. And thats cool, but has he slid into a ditch? Or slid into a curb? Or hit a rea big pothole? Any one of these things could possibly cause his entire unibody to twist with that part gone. And then again maybe it is a completely useless CROSSMEMBER that honda added just to mount the 4ws CPU to. You never know.
I believe that crossmember is only there in the 92-93. didn't they change the 94-96 by having both seats fold down so it eliminated that rear seatsupport. I know in the 97+ they don't even have that.. they have a metal bar that goes underneath the back seat across the body..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MadCityLude »</TD></TR><TR><TD CLASS="quote">
One of the above posters said he had been driving without his for 5 yrs. And thats cool, but has he slid into a ditch? Or slid into a curb? Or hit a rea big pothole? Any one of these things could possibly cause his entire unibody to twist with that part gone. And then again maybe it is a completely useless CROSSMEMBER that honda added just to mount the 4ws CPU to. You never know.</TD></TR></TABLE>
and no to sliding into a ditch.. you act like taking that seat support out is gonna change the whole car and make it so I am driving on ice. and I am a autobody specialist and it hasn't effected my unibody one bit. I live in Utah where the weather is horrible 5 out of the 12 months of the year and my car has handled just fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx »</TD></TR><TR><TD CLASS="quote">you can pretty much say the same for the entire car's body panels if you cut them apart piece by piece, but as a whole assembly, i'd like to see you bend a car on your knee.</TD></TR></TABLE>
ya the outer body panels. but try taking the inner wheelhouse and bending that metal. there is already another metal beam that crosses the back of the car to give it support
number 18. every 4th gen has it..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tacticalcustoms »</TD></TR><TR><TD CLASS="quote">I believe that crossmember is only there in the 92-93. didn't they change the 94-96 by having both seats fold down so it eliminated that rear seatsupport [...]</TD></TR></TABLE>
WRONG...
I have late 94' lude and i have that crossmember. But mine is 4ws tho so it needed to mount the ecu anyway.
WRONG...
