Installing an oil pressure gauge
So im about to install an autometer Z seriers electronic oil pressure gauge. According to this post
https://honda-tech.com/zerothread?id=1739320
I was required a 1/8" BSPT adapter to be able to install the sender unit to the block. However when I was reading it over tonight I noticed one of the members stating..
and I quote
"Oh sorry, I thought I posted the answer.
The block is threaded for 1/8" BSPT fitting. You'll need the block tee that's 1/8" BSPT to 1/8" NPT from stealthmode, or give Stan at Fast-turbo a call. They have all your oiling needs."
Would my adapter from autometer work or do I percisly need the one from Fast-Tubo?
The adapter I purchased can be viewed here
http://autometer.com/cat_acces...id=11
Thanks,
and I quote
Thanks,
TOMSBLUEHONDA23
10
Dec 1, 2004 08:36 AM
Proper
May 4, 2003 02:25 AM
