D16Y8 in a 92 EG DX
Old Sep 11, 2006 | 06:35 PM
Inliner's Avatar
Default D16Y8 in a 92 EG DX PROBLEMS!!!
Alright the engine bolted right up. Were trying to convert it to 0BD1 so we used the D15 Dizzy like you would for a mini me (dremeled out the holes to fit) so we got it all wired up all except the vtec which is easy, but the car wont start. it should run with out Vtec hooked up right? it turns over easy has spark and is getting gas but will not run, its sputtering like it wants to start... any ideas anyone?
Modified by Inliner at 3:57 AM 9/14/2006
Old Sep 11, 2006 | 06:51 PM
FalkenSiR's Avatar
Default Re: D16Y8 in a 92 EG DX (Inliner)
Vtec doesn't have to be hooked up. Is it throwing any codes? Make sure the dizzy wiring is right. Also try loosening the dizzy and as you crank the engine turn the dizzy. If the engine starts, it means your timing is way off.
Old Sep 11, 2006 | 06:58 PM
Inliner's Avatar
dizzy hasnt been touched its 0BD1 already just ran on a D15. tried turning dizzy while cranking still not starting.
Old Sep 11, 2006 | 07:15 PM
FalkenSiR's Avatar
Default Re: (Inliner)
no cel?
Old Sep 13, 2006 | 06:17 AM
Inliner's Avatar
update.. it wouldnt run on the D15 ecu so we put in a p28 and it starts but wont idle and wont rev up at all... no CELs either...
Old Sep 14, 2006 | 02:56 AM
Inliner's Avatar
another update.. well we pulled all the bolts out of the dizzy started teh car wihle holding it rotated it clockwise past the limits of the bolt holes and we can get it to run fine... its very odd any ideas?
1BADEGDC2
12
Jan 1, 2008 12:55 PM
92EG8
16
Nov 23, 2006 07:38 PM
hondahatch741
Sep 8, 2006 05:33 PM
HamiltonRex
Nov 28, 2005 09:53 PM
