Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Broken Hood latch
Old Sep 11, 2006 | 05:05 PM
bgoetz's Avatar
Default Broken Hood latch
Damn this sucks, my hood latch is busted. I am not sure if it is the cable or what, but I can't even get it open to fix whatever it is wrong with it. I have tried using a tool to to hit the switch that opens it, but I have had no luck. Any ideas???
Old Sep 11, 2006 | 07:20 PM
fg2si!kid's Avatar
New User
Default Re: Broken Hood latch (bgoetz)
is there tension on the cable when you pull the lever ?
Old Sep 11, 2006 | 08:43 PM
toyomatt84's Avatar
Sanji
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bgoetz &raquo;</TD></TR><TR><TD CLASS="quote">Damn this sucks, my hood latch is busted. I am not sure if it is the cable or what, but I can't even get it open to fix whatever it is wrong with it. I have tried using a tool to to hit the switch that opens it, but I have had no luck. Any ideas???</TD></TR></TABLE>
I had that happen with my EJ1. I'd recommend buying a new latch along with a new hood release cable. Then grease up the release mechanism on the radiator support. Best of luck.
Old Sep 12, 2006 | 08:21 AM
bgoetz's Avatar
Default Re: Broken Hood latch (toyomatt84)
What you greased it and then it allowed it to release easier?? Because right now I can't get the hood open to even find out what is wrong
bgoetz's Avatar
Default Re: Broken Hood latch (em2!kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by em2!kid &raquo;</TD></TR><TR><TD CLASS="quote">is there tension on the cable when you pull the lever ?</TD></TR></TABLE>
No but you can hear it moving by the mechanism. So it is like it is disconected right at the mechanism
Old Sep 12, 2006 | 11:30 AM
toyomatt84's Avatar
Sanji
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bgoetz &raquo;</TD></TR><TR><TD CLASS="quote">What you greased it and then it allowed it to release easier?? Because right now I can't get the hood open to even find out what is wrong</TD></TR></TABLE>
The latching mechanism itself, and it's under the hood. If the handle is broken, you might want to use a vice grip to pull the cable, so you can release it.
Old Sep 12, 2006 | 08:19 PM
fg2si!kid's Avatar
New User
have you tried pulling on the hood whille some one pulls the lever
is this on an em2 ?
Old Sep 13, 2006 | 01:54 PM
bgoetz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by em2!kid &raquo;</TD></TR><TR><TD CLASS="quote">have you tried pulling on the hood whille some one pulls the lever
is this on an em2 ?</TD></TR></TABLE>
yeah it is like the cable is busted. The biggest problem is that finding out what is wrong should be no big deal I just need to get it open. I am going to take a new approach from under the car reaching up today, I will let you know how it works
dopefeen
Oct 14, 2007 01:04 PM
user 98292739
Sep 5, 2006 08:12 AM
madmanmulligan
May 21, 2006 09:32 AM
jlv55
Oct 8, 2004 04:05 PM
