97 Lude Still bogs like a mofo
Old Sep 11, 2006 | 04:05 PM
loudsubz's Avatar
Default 97 Lude Still bogs like a ****
Its been getting worse lately. Seems that now everytime I start my car, the first few minutes of driving, it likes to bog around 1500-3500 RPM then after 3500 rpm its like a rope snaps and the car just bolts.
I can hear the intake making a low growl noise when its bogging.
I have changed cap/rotor/plugs and did a seafoam last summer, and over the winter is when it got crappier. The only thing I havn't changed is plug wires yet, but when i changed the other parts i measured and the resistance was still within spec on them so I left it.
Got any ideas on what I should check? Does it cound like an O2 issue or clogged cat?
Now after driving around for a min or so, the bogging subsides and it drives pretty good, but isn't as responsive as it used to be.
Old Jun 25, 2007 | 04:54 PM
loudsubz's Avatar
Default Re: 97 Lude Still bogs like a **** (loudsubz)
any input on this?
still doing this
only thing I havn't done is cleaned my egr (CEL 80) but from what I understand the EGR shoulnd't affect this should it?
Old Jun 25, 2007 | 04:56 PM
s_vares's Avatar
Just do my egr test.
Find my tread on it.
It will tell you with $0 and 2 mins if the egr is failing, and I tell you how to fix it.
Old Jun 25, 2007 | 09:36 PM
lude_si_95's Avatar
Default Re: (s_vares)
change your wires...dur. 99% positive thats where your problem is
tUnz_on
Jan 29, 2016 08:25 PM
xtrattitude4u
Jul 8, 2013 07:44 AM
FUPAH8TR
46
Aug 11, 2007 10:02 AM
Dukes69
May 13, 2007 12:44 PM
Nsane
Jun 2, 2006 06:04 PM
