what engine to put in 90 dx?
i'd like to find out what enigne would be my best bet in my 90 civic dx. i drive in the city alot and carry my boys and our gear around to races (downhill bike) so i the extra low end power of a b18 sounds good, but i'm open to suggestions. i'd also like to do something pretty cheap and easy.
i know this doesn't sound like an interesting topic to respond to, but i'm ready to do this now, and what i do will mostly rest on the suggestions you give me now.
I have a 99 ex civic. I will probably (but far in the future I'm afraid
) go with the B18C1 engine (I don't recommend the Integra type R engine cuz personally I want to get a turbo as well).
You can also get a B16B (SiR engine) and I can tell ya that those things are FAST. They have about the same power rating as the B18C1's.
However, if you want low end power, the .2 L helps...
) go with the B18C1 engine (I don't recommend the Integra type R engine cuz personally I want to get a turbo as well). You can also get a B16B (SiR engine) and I can tell ya that those things are FAST. They have about the same power rating as the B18C1's.
i'm actually pretty happy with the low end of my 1.5 L, but i need more power ont he highway and more power so i can carry several hundred extra pounds of people and bikes. the thing is i also have to drive through mountians carrying all this extra weight, so i want something that could take stuff like that in stride.
Theres only one way to go in my opinion and thats a b18. b16a's have no torque and it seems thats what you need. Try looking for a B18a1 out of a 2nd gen integra, real cheap and easy swap. And to solve any confusion the b16b is the JDM type-r engine.
You have many options:
For ease of install and better power: SOHC VTEC or ZC - bolt in with stock mounts, you can keep your tranny, decent power gains
For low end torque: B18A / B18B / B20B / B20Z - all of these require a mount kit, custom shift linkage and wiring.
For high end: B16A - requires a mount kit, custom shift linkage and a little more wiring.
For both high and low: B18C - requires a mount kit, custom shift linkage a little more wiring and a custom hood (bumped in the middle) for clearance.
Then there's also the hybrid beasts: LSVTEC and CRVTEC - big motors with great low end and high end - require a mount kit, custom shift linkage, wiring, custom hood and a little machine work.
For ultimate low end torque - H22 - requires a mount kit, some hacking, pounding welding and stuffing to shoehorn it in there but if you got the $ then you'll have all the low end you need and then some.
