Will they cover it
Old Apr 29, 2002 | 01:11 PM
Veritas-Aequitas's Avatar
Grumpy Old Man
Default Will they cover it
Ok because the search has failed me once again I need some help on if Acura is going to cover a few little things I have wrong with my car. So any oppinions would help.
1. Steering wheel squeeks/vibrates at a certain point when i turn it.
2. Found water in my trunk after hard rain.(I know its been discussed but the search sucks)
3. Clutch squeeks about 1/4 down. Happens when i engage and disengage it.
4. Rubber stripping came off of the window. It is a peice of rubber that runs down the length of the track for the window to go up and down.
5.Driverside headlight is full of water in high and low beams.
If you guys could help it would be great because Beford Acura sucks and I know im going to have to fight with them about it and I was just wondering if these should be fixed or if they are considered "wear" items and are not covered.
[Modified by ReBornGSR, 6:24 PM 4/29/2002]
Old Apr 29, 2002 | 01:26 PM
acuracing's Avatar
Default Re: Will they cover it (ReBornGSR)
Doesn't hurt to try. Those symptoms don't seem like they were your fault.
Old Apr 29, 2002 | 02:21 PM
Nick's Avatar
Default Re: Will they cover it (acuracing)
If your still under warrenty i'm sure they won't have a problem fixing those minor problems.
Old Apr 29, 2002 | 02:23 PM
Grumpy Old Man
Default Re: Will they cover it (Nick)
Oh and my headlight is full of water
Old Apr 29, 2002 | 02:33 PM
ITRacer121's Avatar
yeah my head light is leaking too?
Old Apr 29, 2002 | 02:36 PM
AoiGSR's Avatar
25 Year Member
if you're under 50k, do it. or if you have an extended warranty as well.
i just got my squeaky clutch fixes. would have costed me $600
-AoiB0t, who can't hear any squeaks now.
[Modified by AoiGSR, 3:37 PM 4/29/2002]
audiphile
May 15, 2015 11:19 AM
ribal_gh
Sep 25, 2012 10:00 PM
Zombie Nachos
13
Sep 17, 2010 10:55 AM
Skip01
16
Mar 31, 2010 11:07 AM
cpmajai
Acura TSX
Feb 2, 2010 05:52 AM
