205/55/15 or 195/50/15 on lowered em1 with stock si wheels??
i need to get a new set of tires and I'm trying to figure out what would look the best and provide the least camber wear. what do think? any pics?
205/50/15 or 195/55/15 will work. 205/55/15 is too big. Some people prefer 195/55/15 on a stock 15x6 rim (I prefer 205/50/15). Either size is fine.
I don't have an EM1 but feel free to look in my gallery for pictures of my Integra on 205/50/15. Some people prefer 195/55/15, I prefer 205 width tires with the slightly wider tread. Slightly decreased ride quality because of the shorter profile is the tradeoff though.
As far as tires: what do you want: all-season or summer tires? I just got some Kumho Ecsta SPT from tirerack.com, it came out to about $320 total, and needless to say I am VERY satisfied.
thats good, im running on the cheap side until i can get the funds up... vulcantire.com $38 speacial on 711's
711s are one of the worst summer tires out there. Spend an extra $10 or so a tire and get some DZ101s.
or get the SPT which is a little better then the DZ101 and is way better then the 711 which is horrible I had a set.
at the tirerack they are having a special which give you 40$ off.
Dave
Dave
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K . I . N . G ! »</TD></TR><TR><TD CLASS="quote">55 series, my car. im getting 50's today so i will post up the difference once i get a chance.</TD></TR></TABLE>
Did you rub with those tires?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K . I . N . G ! »</TD></TR><TR><TD CLASS="quote">yes! all the time, now i have the 50's and it rarely rubs</TD></TR></TABLE>
I had them and they didn't rub at all
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shutupnskate »</TD></TR><TR><TD CLASS="quote">You did get 205/50/15 and not 195/50/15, right?</TD></TR></TABLE>
Yep 205's are the way to go
My old EH was about 4 inches from the ground
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Earthworm Jim »</TD></TR><TR><TD CLASS="quote">
195/50/15 or 205/50/15 are both acceptable for a 92-95 Civic. 205/50/15 is slightly too big, which isn't too big of a problem. I have ran both sizes on my old EH2.
I was just seeing the if OP bought 195/50/15 for his EM1, which would be too small.
</TD></TR></TABLE>195/50/15 or 205/50/15 are both acceptable for a 92-95 Civic. 205/50/15 is slightly too big, which isn't too big of a problem. I have ran both sizes on my old EH2.
no i bought the 195's for clearance, everyone thats seen them agrees they are perfect. this is a clean simple daily driver with some bolt ons
the 205's rubbed quite a bit
You bought tires that are too small. Consequently ride quality and speedo reading will be affected. Who told you to buy that size?
well king i think you made the right choice for your vehicle because of the rubbing issue only..........195/50r15 maybe to small but in your case that is what you needed for clearance issues.....205/50r15 would've been better but obviously they rub on your vehicle......how much did you lower your car out of curiosity????????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecsi00 »</TD></TR><TR><TD CLASS="quote">well king i think you made the right choice for your vehicle because of the rubbing issue only..........195/50r15 maybe to small but in your case that is what you needed for clearance issues.....205/50r15 would've been better but obviously they rub on your vehicle......how much did you lower your car out of curiosity????????
exactly... the 195's fit the rims just fine. it's lowered considerably over 3 inches. clearance is much better. still the ocassional rub but nonetheless alot better than the 205/55's. 5mm's less in both demensions is not going to make a big difference in performance
jdmsupreme2132
Mid-Atlantic (Sales)
Sep 7, 2010 02:55 AM
efboy
May 6, 2008 08:50 PM
XyKo
Feb 22, 2005 08:28 AM
SiC CiViC
Sep 15, 2002 03:04 PM
