about high compression and pump gas?
yeah i was thinking about slapping on some ctr pistons in my b16, i did the compression calculator from http://www.zealautowerks.com/, now that being said my compression would be 11:9:1. would that be safe to use 93 octane pump gas or am i going to run into detonation problems?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mechman456 »</TD></TR><TR><TD CLASS="quote">u will hve problems wit detonation
and why is that? people run up to 12.5:1 or even higher on 93 with no problems whatsoever........ this is tuned of course....... anyone in their right mind cant expect it to run with no issues on a stock ecu
im no tuner but people buy 12.5:1 pistons jabboring about how much compression they have blah blah blah. they usually are too stupid to realize is those pistons are 12.5:1 with X head and 0 PTDH. i was one of these fools back in the day. bought some 12.5:1 JE pistons, actual calculated CR was 11.3:1 w/ a B16 head. a far cry from 12.5:1
dam so im going to run detonation problems for sure then huh, what program would be best recomended to run with those pistons? i was thinking getting my ecu chipped with itr or ctr settings since the compression on those are allmost the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 2 NV »</TD></TR><TR><TD CLASS="quote">you arent ready to handle building a motor. read read read the archives. dont touch your car.</TD></TR></TABLE>
lol. hes only looking for some advice. not that i disagree with you but lets keep it friendly. on 93 octane you WILL run into detonation problems with a factory ecu, especially part throttle. with an ecu capable of timing changes, you wont, but you wont be able to really optimize the power the motor is capable of. i have 13.2:1 pistons in my lsvtec and tuned on pump the car doesnt detonate at all, however with c16 i made over 25 more whp on motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nvmyb20hatch »</TD></TR><TR><TD CLASS="quote">
lol. hes only looking for some advice. not that i disagree with you but lets keep it friendly. on 93 octane you WILL run into detonation problems with a factory ecu, especially part throttle. with an ecu capable of timing changes, you wont, but you wont be able to really optimize the power the motor is capable of. i have 13.2:1 pistons in my lsvtec and tuned on pump the car doesnt detonate at all, however with c16 i made over 25 more whp on motor.</TD></TR></TABLE>
so what ecu tuning would u recomend?
you can't just buy a set of 12:5 compression pistons and expect to get that compression off your motor. remember the motor has to be MILLLLED DOWN TO THE SPEC!!! to get that compression or else 12:5 ain't gonna get you a 12:5 but only a 11 or what so ever. and YES! i have a 12:5 fully builted gsr motor running on 93 with dyno tuned with a upgraded s200
so i could have a 11.5:1 je piston and have a 12:1 cpr due to the fact it depends how much you mill the motor? I was thinking about megasquirt's do it yourself engine management, is that a good system in honda tuning?
lol. hes only looking for some advice. not that i disagree with you but lets keep it friendly. on 93 octane you WILL run into detonation problems with a factory ecu, especially part throttle. with an ecu capable of timing changes, you wont, but you wont be able to really optimize the power the motor is capable of. i have 13.2:1 pistons in my lsvtec and tuned on pump the car doesnt detonate at all, however with c16 i made over 25 more whp on motor.</TD></TR></TABLE> That says it all.
well i based my response on the fact he was looking for a "program" not a ECU management system.
i wont sit here and say that generic programs dont work cause when i built my first motor the best program that worked for me was a skunk2 program. i gained 3MPH and 3/10ths over what i already was using. worked good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA_B18C1 »</TD></TR><TR><TD CLASS="quote">you can't just buy a set of 12:5 compression pistons and expect to get that compression off your motor. remember the motor has to be MILLLLED DOWN TO THE SPEC!!! to get that compression or else 12:5 ain't gonna get you a 12:5 but only a 11 or what so ever. and YES! i have a 12:5 fully builted gsr motor running on 93 with dyno tuned with a upgraded s200</TD></TR></TABLE>
i think i covered this alreay.
anyways, id stick with a P28 out of a 92-95 EX or SI which can be had from 100-130 give or take. then get crome for FREE, get a laptop and buy an ostrich for 175 and your set. might want to get a bootlegged copy of crome pro for datalogging purposes.
i got a custom program for datalogging. i think about 5 people have it, most dont even know it exists.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 2 NV »</TD></TR><TR><TD CLASS="quote">i got a custom program for datalogging. i think about 5 people have it, most dont even know it exists.</TD></TR></TABLE>
now we do
........ so go ahead and upload it somewhere
now we do
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 2 NV »</TD></TR><TR><TD CLASS="quote">well i based my response on the fact he was looking for a "program" not a ECU management system.
fine if i get a p28 will u tune it for me?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtaaak y0 »</TD></TR><TR><TD CLASS="quote">Why are you dead set on such High Comp? You'd probably make more power on a lower compression with more timing/tuning.</TD></TR></TABLE>
why becuase of the ctr cams that i have thats why. and they work best with high compression
Yes you can run CTR pistons in a B16 and the compression with a B16 or B18c5 head will be 11:1 ish they have the same head cc at 42.7cc's. you will not have a problem with detonation. you will have to mill the rods by 1mm on each side (small end) to fit any CTR, ITR pistons to stock B16 rods though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2kblusiguy »</TD></TR><TR><TD CLASS="quote">Yes you can run CTR pistons in a B16 and the compression with a B16 or B18c5 head will be 11:1 ish they have the same head cc at 42.7cc's. you will not have a problem with detonation. you will have to mill the rods by 1mm on each side (small end) to fit any CTR, ITR pistons to stock B16 rods though. </TD></TR></TABLE>
i did not know that that is valuable info thanks
