a6 headgasket equivalent in steel?
Old Sep 11, 2006 | 11:18 AM
mattie_96's Avatar
Default a6 headgasket equivalent in steel?
for my a6, z6, y8 hybrid build I need to use the d16a6 head gasket to keep the compression ratio in the area where I want it (10 to 10.2:1). Therefore to do so I need to use the a6 headgasket. I heard it is the old material and not metal so its deteriorates quicker. Are there any steel headgaskets on the market like the y8 one that are the same thickness...or rather could I use 2 y8 headgaskets for example?
Old Sep 11, 2006 | 11:27 AM
mattie_96's Avatar
according to this website,,,the a6 headgasket is 0.048 inches thick...therefore i guess ill have to custom order a steel headgasket for dseries thats about 0.050 inches thick.
http://www.knology.net/~jediklc/D.htm
Old Sep 11, 2006 | 11:54 AM
y-49's Avatar
just use the z6 head gasket. it shouldnt affect the comp ratio to awful much. it will give u more comp which is better
Old Sep 11, 2006 | 11:58 AM
fireant's Avatar
Default Re: (y-49)
Honda has an all-metal head gasket that is a direct-replacement for the old A6 composite gasket...same size, too.
Old Sep 11, 2006 | 02:26 PM
mattie_96's Avatar
thanks again for the info...also I have to use the a6 equivalent or one that is 0.050'' as I am using this engine through the winter for4 months...then in the spring ill use the y8 headgasket and be up to about 11:1 of a CR.
mattie_96
Sep 11, 2006 03:14 PM
baggedmazda
May 7, 2006 03:55 PM
97grnrs
Dec 10, 2005 11:11 AM
mike93eh
Jul 25, 2005 03:42 PM
fastcrxsi90
May 1, 2003 06:48 AM
