96 GSR swap w/ITR cams
Old Sep 11, 2006 | 08:41 AM
LvN's Avatar
LvN
Default 96 GSR swap w/ITR cams
Ok, my friend just bought an EG with a 96 GSR swap with ITR cams.. he's running on a p72 ecu now but also have a p28 chipped ecu that he can use to run crome later.. Can he use the stock valvetrain with ITR cams?? Also, the car runs good but vtec isn't that noticeable, it has a stock intake, manifold, obx header, stock piping to exhaust. Is the GSR vtec engagement not too noticeable since it still has the butterfly IM?? Not too familiar with GSR motors. Thanks in advance.
Old Sep 11, 2006 | 09:08 AM
spooncivic1's Avatar
i'd upgrade to at least an AEBS intake manifold. they are cheap ($130 new on Ebay)
Old Sep 11, 2006 | 09:11 AM
LvN's Avatar
LvN
Default Re: (spooncivic1)
would that help somewhat? with the gsr ecu would it have 2 vtec engagements?
Old Sep 11, 2006 | 09:24 AM
SiB16A's Avatar
should invest n a single stage IM
Old Sep 11, 2006 | 09:30 AM
Default Re: (blkcivicpn0i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkcivicpn0i &raquo;</TD></TR><TR><TD CLASS="quote">would that help somewhat? with the gsr ecu would it have 2 vtec engagements?</TD></TR></TABLE>
the 2nd engagement is the IAB's (secondaires). but to get the most out of cams you'd need a single stage intake manifold. it would also help to have a better fuel maps, which you can get with a chipped ecu, as long as the person knows how to make a decent basemap.
and yes, stock vavletrain can be used. but i wouldnt take it over 8500 personally.
Old Sep 11, 2006 | 09:37 AM
-=Zeqs=-'s Avatar
Default Re: 96 GSR swap w/ITR cams (blkcivicpn0i)
stock gsr valvetrain has only single springs on the exhaust side. your friend should not run the itr exhaust cam on there, but can. the chance for engine failure is more probable than if he were to run a gsr exhaust cam. this coming from a guy on bc3+ cams with stock itr valvetrain though...
Old Sep 11, 2006 | 09:38 AM
LvN's Avatar
LvN
Can he get a ITR basemap to use until he fully tunes it later? He has a chipped p28.
Old Sep 11, 2006 | 04:49 PM
Default Re: 96 GSR swap w/ITR cams (-=Zeqs=-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -=Zeqs=- &raquo;</TD></TR><TR><TD CLASS="quote">stock gsr valvetrain has only single springs on the exhaust side. your friend should not run the itr exhaust cam on there, but can. the chance for engine failure is more probable than if he were to run a gsr exhaust cam. this coming from a guy on bc3+ cams with stock itr valvetrain though...</TD></TR></TABLE>
its been proven multiple times that you can run ITR/CTR on stock valvetrain if you keep the stock revlimit...i personally had them on a GSR with no problems, along with alot of other people i know
Old Sep 11, 2006 | 07:08 PM
SiB16A's Avatar
Default Re: 96 GSR swap w/ITR cams (spooncivic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spooncivic1 &raquo;</TD></TR><TR><TD CLASS="quote">
its been proven multiple times that you can run ITR/CTR on stock valvetrain if you keep the stock revlimit..</TD></TR></TABLE>
Old Sep 11, 2006 | 07:20 PM
i forgot to add also. the GSR exhaust springs are the SAME part # as ITR intake springs, so really you could just put the exhaust side on the intake, and get new ITR exhaust springs...but he should be fine on his gsr valvetrain...just get a good basemap
Old Oct 5, 2006 | 06:20 PM
daver's Avatar
i forgot to add also. the GSR exhaust springs are the SAME part # as ITR intake springs, so really you could just put the exhaust side on the intake, and get new ITR exhaust springs...but he should be fine on his gsr valvetrain...just get a good basemap</TD></TR></TABLE>
let me add that what he said is backwards.
Old Oct 5, 2006 | 06:25 PM
daver's Avatar
its been proven multiple times that you can run ITR/CTR on stock valvetrain if you keep the stock revlimit...i personally had them on a GSR with no problems, along with alot of other people i know</TD></TR></TABLE>
proven? did you or your friends measure the the valvetrain before and after to prove that there was no accellerated wear? Just because your engine doesn't blow up in X amount of miles doesn't mean its 'OK'. Just because you don't rev past the stock redline doesn't mean the spring doesn't have to work harder, it does.
d
Jowee
25
Aug 29, 2020 02:43 PM
thatwhiteguy
Feb 7, 2008 08:21 PM
SOL-Hatchback
Nov 8, 2007 08:03 AM
JDMkidGSR
Sep 8, 2005 05:50 PM
IGotVTECyo
Jun 24, 2005 03:44 AM
