SRS Airbag light...?'s
Old Sep 11, 2006 | 02:10 AM
99SilverBullet.b45!'s Avatar
Default SRS Airbag light...?'s
I have a 99 ex and I was wondering how to get rid of the SRS airbag light from constantly being on (it just bugs the **** out of me) I took the fuse out once on accident and now when I put it back in the correct spot with the correct fuse it just stays glowing?
THIS IS A CALL FOR HELP/ANSWERS!
Old Sep 11, 2006 | 05:31 AM
F20Cteg's Avatar
Default Re: SRS Airbag light...?'s (scsmith1987)
1. Turn off ignition
2. Connect the SCS service connector (or paper clip) to the 2pin wire you take out of the drivers fuse box (yellow connector) and is now hanging from a thicker harness.
3. Turn on ignition
4. SRS light comes on for 6 sec and then goes off. Before it has been off 4 sec, Remove the SCS connector (paper clip).
5.SRS light turns on again. Reconnect the SCS service connector withen 4 sec of light coming on
6. Light goes off, remove connector witeh 4 sec after light went off.
7. SRS light blibks 2 times telling you the memory is erased.
8. Turn ignition off for 10 seconds and start car
Old Sep 11, 2006 | 06:17 AM
sleepencivic's Avatar
Default Re: SRS Airbag light...?'s (F20Cteg)
thats it
Old Sep 11, 2006 | 06:25 AM
itsjdmbradyo!'s Avatar
awesome i was wondering how to get mine off too, thats all? and stealerships charge like hundreds of dollars to do that?!? ahhhahahaha
thanks
Old Sep 11, 2006 | 06:29 AM
xbeamelite's Avatar
Default Re: SRS Airbag light...?'s (itsJDMbradyo!)
does this disable the SRS in the passenger side tho? or is it just resetting the light?
Old Sep 11, 2006 | 06:46 AM
biggdogg's Avatar
Default Re: SRS Airbag light...?'s (xbeamelite)
it resets the whole srs system . now everything will work just like honda intended it too. I LOVE MY 94 SI .
Old Sep 11, 2006 | 09:11 AM
dem0nk1d's Avatar
Default Re: SRS Airbag light...?'s (biggdogg)
If you have the air bag out, and want the srs light to go off. Go out and buy a 2 OHM resistor just a plain "2 OHM" not 2.2k or 2k ohm "just 2 ohm." You can either clip the harness connection from the old airbag and solder it across the connection. Plug it back in, do the rest code and your set no more pulling the bulb, to keep the light off.
luis_ej8
Honda Fit
Jan 8, 2024 11:12 AM
mikeyboost
Mar 26, 2008 08:45 AM
02accordsir
Aug 10, 2004 04:24 PM
LSVTEC408
Jan 2, 2003 12:52 AM
