shaking 91' accord
Old Sep 10, 2006 | 06:50 PM
gdhall's Avatar
Default shaking 91' accord
I have a 91 Accord. It vibrates really bad when it idles. If i rev the engine at while waiting at a stop light it does not vibrate nearly as bad. Also it does not vibrate during normal driving. I think it has something to do with the idling. All the motor mounts have been replaced and it did not help the problem. It does not vibrate as much with the AC off but it is still agrivating.
Old Sep 10, 2006 | 07:07 PM
sooskay's Avatar
Default Re: shaking 91' accord (gdhall)
Same here, my 96 Accord vibrates a lot when idling with the AC is on, but once I turn the AC off it's fine.. anyone know why this happens and how I can fix it?
Modified by sooskay at 8:20 PM 9/10/2006
Old Sep 10, 2006 | 08:06 PM
JohnD1079's Avatar
Hey, i have a 92 Accord LX and it does that too. when youre at a stop light or something the car vibrates BC the rpm goes down to low. Mine only does this sometimes, like it only dips down inot low RPMs. my friend told me thats a sign that your motor could possibly be ready to die, (or at least thats what he said about my car). But what u can do is adjust the idle valve. Its where the gas wire under the hood is. I cant describe it, and I dont even know if honda's have it. but i know nissans do. CHeck somewhere around the gas wire under the hood. there should be a place where u insert a hex key and tighten or loosen it. Hope this helps
Old Sep 10, 2006 | 08:50 PM
CB7VTEC's Avatar
Start with the motor mounts, the front and rear are most often changed while the 2 side mounts are usually forgotten. If you have old mounts, the increased load from the AC comp. kicking in will exaggerate engine vibration considerably. If any adjustment is made to the base idle via the screw on the TB, make sure it's set to spec and not increased to smooth the vibration. Don't even mess with the throttle cable either unless you know it's been tampered with.
Old Sep 11, 2006 | 01:44 PM
eeleaj's Avatar
Default Re: shaking 91' accord (CB7VTEC)
it s could that your mounts are going, or your idle air control iac valve. maybe your timing is retarded slightly.
Aja1997
Apr 15, 2017 07:58 AM
gatormeup
Oct 30, 2011 04:35 AM
cascas
Jul 29, 2011 05:57 PM
gumbysix
Acura TL, RL & ZDX
Sep 10, 2005 11:31 AM
Uglycarman
Aug 10, 2004 07:08 PM
