Just installed HID lights on my bike
Old Sep 10, 2006 | 06:48 PM
.MilanoRex's Avatar
Default Just installed HID lights on my bike
After debating it for a few months, i finally broke down and bought a HID system for my bike... the light it puts out on the road is amazing, VERY bright with a nice cutoff so it doesnt blind cars(tested by having my wife drive infront of me ) the setup was plug and play, but I wanted to be fancy by hooking up a relay and a push button so I dont double fire the ballasts on startup.
The pictures dont do it justice, but you get the idea..
before..
during..
after..
Old Sep 10, 2006 | 06:49 PM
Gant's Avatar
can u post a how to on the relay set up? i to have a 600rr.
Old Sep 10, 2006 | 06:55 PM
sup gurl's Avatar
Looks great! Was it just the low beam or also the high?
Old Sep 10, 2006 | 07:02 PM
.MilanoRex's Avatar
Default Re: (Ba4)
I followed this guys how-to:
http://www.600rr.net/vb/showth...pp=15
I didnt have to cut any of my wiring harness though.. this is what I did so its a little less confusing..
using an automotive relay..
terminal 30: switch side of negative headlight wire
terminal 87: ballast side of negative headlight wire
terminal 86: positive headlight wire
terminal 85: to a normally open momentary switch (other side of switch to terminal 30)
then add a jumper from terminal 87 to 85.
Old Sep 10, 2006 | 07:04 PM
.MilanoRex's Avatar
Default Re: (sup gurl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sup gurl &raquo;</TD></TR><TR><TD CLASS="quote">Looks great! Was it just the low beam or also the high?</TD></TR></TABLE>
Thanks! only the low beam for now since I only use the high beam for flashing people.. but maybe down the road. The low beam puts out more than enough light.
Old Sep 10, 2006 | 07:18 PM
Gant's Avatar
ive seen that thread be4 just need to see a picture of how its actually all wired in.
Old Sep 13, 2006 | 08:30 AM
built562's Avatar
Default Re: (Ba4)
yeah i would like more info on this as well and a pic of how its wired and stuff, also a pic about 10-15ft away from a wall to see glare
Old Sep 13, 2006 | 08:54 AM
ballsack's Avatar
Should have used the money for some riding boots.. BUT thats just my opinion and it stinks.
Old Sep 13, 2006 | 09:01 AM
JoshRambo's Avatar
Default Re: (********)
I just put an HID in my 600rr.
Why the relay?
Old Sep 13, 2006 | 12:56 PM
EX-JAY's Avatar
Default Re: (JoshRambo)
The HID unit draws more power on start up then the regular halogens bulbs. The electrical wiring might melt or cause problems down the road. When I did my HID set up, i just tapped the stock wiring. So far so good.
Old Sep 13, 2006 | 01:38 PM
yimmy's Avatar
Default Re: (EX-JAY)
I have only blown one fuse with my hid's and mine has 2 hid's. You should think about putting one in your other headlight also and just having them both on. My friend has both on his 1000rr and it looks hawt. Either way yours looks
Old Sep 13, 2006 | 04:25 PM
.MilanoRex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ******** &raquo;</TD></TR><TR><TD CLASS="quote">Should have used the money for some riding boots.. BUT thats just my opinion and it stinks. </TD></TR></TABLE>
I have my icon boots on in the last pic, the other pics were taken right after i installed it
I used a relay to prevent double firing of the ballast on startup(which blows fuses and decreases the life of the bulb and ballast) so I startup my bike, then push a button to start the headlights. The HID is 35watts compared to stock 55w so no worries..
thanks for the comments! I might take it apart this or next weekend to install some more stuff and maybe clean up the wiring a little bit. I'll take pictures if I do
Old Sep 13, 2006 | 04:27 PM
.MilanoRex's Avatar
Default Re: (built562)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by built562 &raquo;</TD></TR><TR><TD CLASS="quote">yeah i would like more info on this as well and a pic of how its wired and stuff, also a pic about 10-15ft away from a wall to see glare</TD></TR></TABLE>
I'll try to take one tonight, but the cutoff is clean and it doesnt blind oncomming drivers
Old Sep 13, 2006 | 04:45 PM
ballsack's Avatar
Default Re: (RedHatchBlack)
Good man on the boots!
Old Sep 13, 2006 | 08:21 PM
.MilanoRex's Avatar
Default Re: Just installed HID lights on my bike (RedHatchBlack)
kinda blurry but you get the idea on the cutoff and light output..
Modified by RedHatchBlack at 6:35 AM 9/17/2006
Old Sep 16, 2006 | 09:43 PM
.MilanoRex's Avatar
for anyone who wanted to see how I wired the push button.. I built a whole new harness from the ground up and installed it..
Here's the whole thing
Here's how it's plugged in to the relay
You can see where I put everything, I made the wires a little longer than needed incase I ever wanted to move it somewhere else... I just folded and ziptied the slack(no pictures though)
Here's the left ram air cover installed, it all fits perfect... you can also see where I placed the push button
You can see it's completely hidden.. the black and red wires go straight from the ballast to the light socket.
Modified by RedHatchBlack at 8:50 AM 9/17/2006
Old Sep 16, 2006 | 10:08 PM
ngng's Avatar
i wouldnt ever put anything &gt; 5400...maybe 6000k on the bike
il ike the relay though
Old Sep 16, 2006 | 10:46 PM
kihun_cha's Avatar
I just bought a HID kit (single) low bim but is the rely nesscesary?
Old Sep 17, 2006 | 12:28 AM
JDM_is_Rice's Avatar
Default Re: (kihun_cha)
looks good, i might do the same thing on my 600rr also
Old Sep 18, 2006 | 08:47 AM
lshybrid195's Avatar
Default Re: (SL65 AMG)
i have 6000k in both my 929rr and my 750.. love them!
on the 750 i have them in the high beams slots just so on start up i they are no on.. the low beams i have luminatic's bulbs so it blends well when the HID's are on... since the lights are in one houseing and side by side i almost never have just 1 side on
delpoop!
Texas -OK -LA (Sales)
Apr 24, 2008 08:29 PM
IT'S ME DAVID
Honda Motorcycles
19
Aug 31, 2007 05:36 AM
Wimpy.
Honda Motorcycles
13
Aug 5, 2005 12:46 AM
Fuster_Cluck
Honda Motorcycles
23
Feb 19, 2004 05:45 PM
evil vapor
Honda Motorcycles
12
Nov 3, 2001 09:05 PM
