header wrap? for h22?r
Old Sep 10, 2006 | 02:55 PM
darkstar1440's Avatar
Default header wrap? for h22?r
I've heard of people using header wrap on their header does anyone know what we could get from putting it on h22 exhaust manifolds?
Old Sep 10, 2006 | 04:02 PM
petern101's Avatar
Default Re: header wrap? for h22?r (darkstar1440)
but why?
i've never needed header wrap. if you want it, you can use it. but on a stock oem manifold, it won't do anything. and probably is a waste of money.
Old Sep 10, 2006 | 04:07 PM
M2B4's Avatar
Default Re: header wrap? for h22?r (petern101)
header wrap keeps heat in also...something to think about
Modified by M2B4 at 8:04 PM 9/10/2006
Old Sep 10, 2006 | 04:35 PM
2point6's Avatar
Default Re: header wrap? for h22?r (M2B4)
I wraped my first DC header years ago... sold it to a friend who had it on his car for 5 years until a pack rat decided to eat it all. Worked fine, but not needed.
Old Sep 10, 2006 | 04:54 PM
LudeBehavi0r's Avatar
The heat wrap is designed to keep heat from disappating into the engine bay, and sometimes to keep moisture from making contact w/the head and thus preventing rust.
Old Sep 10, 2006 | 05:59 PM
BB6racer's Avatar
i just installed some headre wrap on my car last weekend. didn't make any power, but lowered engine bay temp a lot more than i was expecting. exhaust got a little louder i think though...maybe because the exhaust gasses are hotter and flowing faster??? plus for only $30 why wouldn't you give it a try?
Old Sep 10, 2006 | 10:38 PM
HondaTheory's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkstar1440 &raquo;</TD></TR><TR><TD CLASS="quote">I've heard of people using header wrap on their header does anyone know what we could get from putting it on h22 exhaust manifolds?</TD></TR></TABLE>
I have been running exhaust wrap for 6 months on my stainless steel header. So far so good. I can't really compare between not haveing the wrap verses having it, since I wrapped it *before* I installed the header. You can take a look at it here:
https://honda-tech.com/zerothread?id=1541289
I actually asked the guys here in the forum if I should have a heat shield or not, and well so far so good. No discoloration on the hood or anything.
One thing I have been told is that you should not put heat wrap on a ceramic coated header or cast. Wrapped cast will eventually rot.
Hope that helps.
Old Sep 11, 2006 | 11:22 AM
Chuckles99SH's Avatar
If your header is cheap it opens up the door for cracking the weilds.
JDM-h22a
Oct 13, 2009 06:57 PM
RUBZERK
Apr 2, 2004 11:09 PM
H23A1LUDE
Aug 29, 2003 04:13 PM
LSintegra
Nov 14, 2002 06:54 AM
Lo-Buck EF
26
Sep 5, 2002 01:26 PM
