6x9 boxes (noob alert)
Old Sep 10, 2006 | 11:14 AM
ronald55555's Avatar
Default 6x9 boxes (noob alert)
i have rockford 6x9s in these boxes
http://www.futureshop.ca/catal...catid=
after i put them in, the cone moves a lot less than it did before when it was mounted at the oem location(rear deck on an ek). Does that mean it needs more airspace? do i just drill a hole in the front of the box?
Old Sep 10, 2006 | 12:22 PM
fcm's Avatar
fcm
Old Fart
Default Re: 6x9 boxes (ronald55555)
Yes, the small box "over controls" the cone, 6x9s are designed for the average car trunk however just drilling holes in the box may not solve the problem, and could in fact cause more problems, you are going from a sealed cabinet to a "ported/vented" one. 94
Old Sep 10, 2006 | 01:36 PM
Default Re: 6x9 boxes (fcm)
so what do i do?
Old Sep 10, 2006 | 01:38 PM
the cone barely move at all, where as before, they go up and down a lot. It sounds ok in the box, but would it cause problems for the speakers?
i'm not a sound guy as you can probably tell, the whole reason i put them in the box is so that i can remove everything easily for autox/track days, since the box is held down by velcro tape.
Old Sep 10, 2006 | 02:13 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
If it sounds good and the speaker is not putting out any distrortion then leave it alone. It not going to break the speaker. Over powering-underpowering a speaker and distortion is a speaker enemy also weather too.
Old Sep 10, 2006 | 04:27 PM
85's Avatar
85
Default Re: 6x9 boxes (wrx-killer-Sti eater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti eater &raquo;</TD></TR><TR><TD CLASS="quote">If it sounds good and the speaker is not putting out any distrortion then leave it alone. It not going to break the speaker. Over powering-underpowering a speaker and distortion is a speaker enemy also weather too.</TD></TR></TABLE>
Old Sep 10, 2006 | 06:32 PM
JSPECSIR's Avatar
Default Re: 6x9 boxes (hks85)
maybe polyfill would help?
Old Sep 10, 2006 | 09:27 PM
what about when i get an amp for that speaker? is it enough airspace for the speaker?
Old Sep 10, 2006 | 09:41 PM
you will be fine. When you get the amp just make sure you tune it so there is no distortion. When your 6x9 are mounted in the trunk there is no pressure support on the cone. So the speaker goes into a free air state. That can damage a speaker because of to much excursion. And when you hear the distortion you turn it down. Same for when you get your amp.
'Accord Ex'
Audio / Security / Video
15
May 30, 2007 01:36 PM
'Accord Ex'
May 28, 2007 08:24 PM
hometheaterman
May 16, 2005 09:24 PM
xXxS_SxXx
Oct 11, 2003 01:46 AM
GoLowDrew
Jul 28, 2001 09:52 AM
