Greddy turbo timer install(I searched) but something extra
Got this, I figured out where the red blue and green wires go. but down on the harness closer to the timer itself there is a one grey wire, and then there is a purple and a brown that go to a little plug. My question is where does the grey wire go? and where does the plug that the purple and brown wires run to, go? Thanks in advance. I haven't tried to put this on yet, so if its blatantly obvious once you take the column off excuse my ignorance, just wanted to get an idea before I go taking stuff off in the heat.
Figured out you don't use the grey wire. and that the brown wire goes to the ground wire on the E-brake, im guessing so that the autotimer will only work when the e-brake is pulled? Purple wire goes to "speed signal wire" coming out of ECU. Im gonna assume this is so the thing will read the cars speed? Do EF's have speed sensors? I thought they just used speedo cables. but I dunno. thanks
thanks. I figured it out later that day though. I don't think that is to display the speed on the timer is it? I thought it was just another safety thing like the E-brake thing. That cuts the timer off if the vehicle starts moving.
