half shafts
Old Sep 10, 2006 | 06:37 AM
SLO Sol's Avatar
Default half shafts
should i replace both halfshafts? my drivers side boot is completely done this is an issue that i know needs attention quick.
Old Sep 10, 2006 | 07:38 AM
DelSolMarine's Avatar
Default Re: half shafts (D-money 92si)
dont fix what aint broken... just fix the one with the busted boot and actually replace the axle dont just put a new boot on it
Old Sep 10, 2006 | 01:06 PM
SLO Sol's Avatar
Default Re: half shafts (DelSolMarine)
i wasnt sure if it was like brakes or not thanks
Old Sep 10, 2006 | 01:22 PM
JDM-97CX's Avatar
If the boot is all that is bad why don't you just replace the booot? No sense in trashing a good shaft because a boot ripped.
Old Sep 10, 2006 | 03:01 PM
SLO Sol's Avatar
Default Re: half shafts (JDM-97CX)
well its already lost all the lube... and by the time you get to the boot you have already taken the half shaft out you mise well just put a new one in after all that work
Old Sep 10, 2006 | 03:12 PM
1992Si's Avatar
Nobody in there right mind would waste the time to remove the axle to just change the boot. The axle cost less then $60.00. If you know someone you can get them for less then that.
If I were going to change one for the first time, this time of year. I would consider changing both, if they have never been chaged before. Winter is coming. I won't take the chance that the other will make it through Winter. Do you feel like chaning one in say January?
oldskoolDA6
Jul 9, 2009 11:39 AM
nbcivic
11
Nov 8, 2006 11:09 PM
$amGD3
Oct 2, 2005 03:24 PM
calean
Nov 10, 2004 06:04 AM
davidbui
Jan 13, 2002 04:17 AM
