quick question concerning HF using DA knuckles
I have a bone stock '91 CRX HF.
My buddy has a junk DA he is about to get hauled off and I want to use the disc brakes on it.
I plan on driving the car everywhere i go and not towing it.
If i put the DA knuckles on the front, I'm pretty sure the HF axles won't work. Does anyone have different info on this? If I'm right, would I be able to put some SI or DX axles in where I can drive my car home, then later to the shop where I can put my B series in?
thanks for the help
cliffsnotes= will stock HF axles work with DA knuckles? if not, will stock SI/DX axkes work with DA knuckles (still on stock HF motor/tranny)
thanks for the help
if your swapping in a b-series, you need 90-93 integra axles anyways. D-series axles wont work. Also you need different knuckles anyways as the stock HF knuckles wont except the 90-93 integra axles. So, if I was you i'd put the 90-93 integra knuckles in along with the proportoining valve and brake booster/master cylinder.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shoemaker617 »</TD></TR><TR><TD CLASS="quote">if your swapping in a b-series, you need 90-93 integra axles anyways. D-series axles wont work. Also you need different knuckles anyways as the stock HF knuckles wont except the 90-93 integra axles. So, if I was you i'd put the 90-93 integra knuckles in along with the proportoining valve and brake booster/master cylinder.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shoemaker617 »</TD></TR><TR><TD CLASS="quote">if your swapping in a b-series, you need 90-93 integra axles anyways. D-series axles wont work. Also you need different knuckles anyways as the stock HF knuckles wont except the 90-93 integra axles. So, if I was you i'd put the 90-93 integra knuckles in along with the proportoining valve and brake booster/master cylinder.</TD></TR></TABLE>
i don't think you understand my question at all. Please read my whole post. I know what it takes to drop the B series in. The question I'm asking is what D series axles are needed to run the stock HF motor in the crx with the DA knuckles. I have to be able to drive the car around where I can drive it to the shop where I will eventually drop my B16 in.
Yes dx/si axles will work with the da knuckles. the hf axles however will not work
dx/si hf/std axles have the same size inner part of the axles however the out part of the axles is where they differ.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Magick211 »</TD></TR><TR><TD CLASS="quote">Yes dx/si axles will work with the da knuckles. the hf axles however will not work
dx/si hf/std axles have the same size inner part of the axles however the out part of the axles is where they differ.</TD></TR></TABLE>
this guy has his **** in order.
hf/std-23 spline outer
everything else-26 spline outer
thanks a million. just changed over the title to my name today, now i need to locate some dx/SI axles or just make something that will work so I can drive the car back home and then to the shop to put my killer B in.
Correct answers rock!
I did this swap on my old CRX HF. I even used 4 door ef axles. Wait till you feel how much the big brakes cause the HF to accelerate slower. Don't forget to get an alignment.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnnieChimpo »</TD></TR><TR><TD CLASS="quote">Correct answers rock!
I did this swap on my old CRX HF. I even used 4 door ef axles. Wait till you feel how much the big brakes cause the HF to accelerate slower. Don't forget to get an alignment.</TD></TR></TABLE>
the big brakes shouldn't be too much of a problem with 260+ WHP on hand all motor
EX and DA spindles run the same calipers and discs.
With the correct caliper bracket (Accord Wagon, etc) you could run ITR sized brakes.
I do not know what is required to press in 5 lug hubs. You can probably just swap in a bearing with the correct inside diameter or machine the hubs to the correct size.
firejackal
Jul 12, 2012 10:11 AM
skiracer8148
Apr 12, 2007 07:27 AM
50shotRex
Feb 16, 2003 05:07 PM
