Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
06 civic oil filters?
Old Sep 10, 2006 | 04:03 AM
lowlavar's Avatar
Default 06 civic oil filters?
ok. I changed my oil for the first time in my 06 civic EX coupe (1.8L). The oil filter i pulled off the car looked different than the oil filter I had to replace it. Both were manufuactured by honda. The size was the same but internally there were some slight difference i.e. there were 6 ports instead of 8. Ive heard all hondas use the same oil filter now except for the s2000 and the pilot. Any help on this topic would be appreciated.
Old Sep 10, 2006 | 06:08 AM
tsdunay's Avatar
Default Re: 06 civic oil filters? (lowlavar)
it could be a new version of the oil filter. If the model numbers match on the oil filter, then its all good.
Old Sep 10, 2006 | 09:12 AM
nsxmatt's Avatar
The filter on the car from the factory is different than the ones you'll get as a replacement. The only ones that are completely different are the S2000 and Insight filters, and of course 84 and older cars.
Old Sep 10, 2006 | 07:30 PM
TRE_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lowlavar &raquo;</TD></TR><TR><TD CLASS="quote">except for the s2000 and the pilot. </TD></TR></TABLE>
Pilot uses the same filter as every other honda like matt mentioned, only different filters are for the 3cyl insights and for the s2k's. As long as youre using a 15400-PLM-A01(or A02), youre fine
Old Sep 11, 2006 | 07:24 PM
COMplex.'s Avatar
Default Re: 06 civic oil filters? (TRE_)
I've heard of some people running S2K filters instead. Any benefits/problems?
Old Sep 11, 2006 | 07:27 PM
nsxmatt's Avatar
Default Re: 06 civic oil filters? (j.fuggi)
People have used them because they are a better quality filter with larger capacity and slightly lower oil pressure for turbo applications but if Honda thought they were better they would have used them on the car to begin with i'm sure.
nicholasellin
Honda Civic (2001 - 2005)
May 6, 2014 09:52 AM
shawnlee250
Aug 3, 2011 12:54 AM
rohec04
Aug 7, 2007 10:11 AM
00pyITR
Dec 15, 2003 07:42 AM
