Installed the gauges..
Old Sep 10, 2006 | 03:27 AM
mrchris1979's Avatar
Default Installed the gauges..
My climate control has no use except to turn the fan on/off. The fan switch is connected and in the glove box. I figure since I don't have AC and only need heat I had no use for ugly stock climate control. This is in an '88 CRX where all the climate controls are cable driven, very simple mechanics. The cables are all still accessible to allow some heat control and changing the vent directions, so for now I have the vents directed to the floor and windshield. If it gets too hot, I'll just roll the windows down a bit or adjust the coolant valve on the heater core via the cable inside the cabin. I'll be making a few of these for my fellow EF'ers with a similar set-up so anyone else interested let me know. The final piece will be in 100% carbon fiber or kevlar.
Old Sep 10, 2006 | 03:56 AM
SETI20's Avatar
I hope for your sake it doesn't get cold where you live. Fogging up windows is common in CRXes.
Old Sep 10, 2006 | 04:13 AM
CRX Toad's Avatar
Default Re: Installed the gauges.. (mrchris1979)
Looks pretty similar to these that I make.
Old Sep 10, 2006 | 04:45 AM
Default Re: Installed the gauges.. (CRX Toad)
This car is not my daily driver and it's only driven on dry weather and mild conditions so the fogging issue should not be a problem. To CRX Toad, are yours laser cut and what material is your template made of? Are you still selling them? A few of my buddies did not want carbon fiber so I'm glad to see someone else can make these. PM me your price per piece and ordering info. Thanks.
crazyboy
Aug 30, 2011 07:14 PM
98greensi
Oct 13, 2007 03:47 PM
M75
Jan 30, 2004 03:27 AM
2k1_ITR_0736
Jun 19, 2003 02:00 PM
