cams help
i had aftermarket cams in my jdm b16a motor and had both intake and exhaust cams set at 00 degrees until i was able to get to a dyno and tune my caar with the new cams(approx 2 months).....if you have aftermarket cams, it wont hurt to set both intake and exhaust cams at 0 degrees.........the only thing is that the aftermarket cams are just a little bigger than your stock ones........only thing is is that your cams wont be as affective for HP until you adjust them based off of dyno readings.......................good luck man!
civbeater90
Mar 4, 2003 05:16 AM
