how do i fix these codes
Old Sep 9, 2006 | 10:49 PM
SoHc94's Avatar
Default how do i fix these codes
so i just ran a code check. and i got the following
#10 Intake Air Temperature
#17 VSS
#16 injectors
how do i got about fixing these.
Old Sep 9, 2006 | 11:10 PM
JICEK9's Avatar
Default Re: how do i fix these codes (SoHc94)
more info is needed to help you. why did you decide to pull codes? is the cel always on? how long has it been on? how does the car run? what is the setup? mods,year of car, milage, motor etc...
Old Sep 9, 2006 | 11:22 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoHc94 &raquo;</TD></TR><TR><TD CLASS="quote">so i just ran a code check. and i got the following
#17 VSS
#16 injectors
how do i got about fixing these.</TD></TR></TABLE>
the only way to fix them is replace or repair these items then leave battery unplugged for about 5 minute to clear the ecu.
Old Sep 11, 2006 | 08:26 PM
SoHc94's Avatar
alright well. i just replaced the fuel filter. and now im only getting a code 10.... wierd huh. intake air tempature sensor is located where on a z6 head with stock manifold. in a 94 ex.
Old Sep 11, 2006 | 08:33 PM
JICEK9's Avatar
Default Re: (SoHc94)
i'm not for sure but IAT's are either in the intake tube themselves, or in the IM. mine it's in the intake. (00 civic ex)
Old Sep 11, 2006 | 08:36 PM
SoHc94's Avatar
should it be hard to find? and would that cause for a rough idle?
Old Sep 11, 2006 | 09:28 PM
instrument's Avatar
no
yes.
godruler
Oct 12, 2009 06:48 PM
SOUTHCREX
Sep 24, 2002 04:35 PM
9d9GSR
Aug 15, 2002 05:21 PM
