Installing Air/Fuel Gauge?? Colbalt brand
Old Sep 9, 2006 | 10:39 PM
HondaPH22's Avatar
Default Installing Air/Fuel Gauge?? Colbalt brand
can anyone give detailed instructions on how to install this on my car? I am running a broken pyrometer right now that I want to replace with this colbalt air/fuel. Need some help!
Old Sep 10, 2006 | 01:30 PM
ef93si's Avatar
find your ECU
tap into the blue wire
power and ground
done.
Old Sep 10, 2006 | 03:30 PM
Speedra500's Avatar
Default Re: (ef93si)
narrowband A/F gauges are garbage, unless you're just getting it to look pretty theres not much point in it
Old Sep 11, 2006 | 03:11 PM
HondaPH22's Avatar
Default Re: (Speedra500)
I have a innovate motorsports a/f hooked up, are they any good?
Old Sep 11, 2006 | 05:09 PM
TylerC161's Avatar
Its not the brand so much that makes it "good", but moreless the wide band, or, narrow band..
If your a.f gauge has 3 wires, power, ground, and a wire to tap into your existing o2 sensor, then its no good..
if it came with an aftermarket o2 sensor, then its good.
Old Sep 11, 2006 | 05:21 PM
MadCityLude
Guest
Posts: n/a
Default Re: (TylerC161)
come one guys, he didn't ask us what we thought of the gauge he bought, he asked how to hook it up.
Sorry man I would tell you, but I don't know how.
Old Sep 11, 2006 | 11:35 PM
My292Ludes's Avatar
Default Re: (MadCityLude)
3 or 4 wires
3 wires
+ ignition
- is ground
and a O2 wire
4 wires
+ ignition
- is ground
O2 wire
and Dimmer wire to run to headlights
Easy enough. And IMO any air / fuel gauge is better than none at all.
si_motor_spt
Jul 14, 2008 09:36 AM
JDMhondalude22
Oct 26, 2006 06:14 AM
Multra Corakus
Apr 21, 2006 09:00 PM
URtaxes
Oct 9, 2005 06:32 PM
integra0260
Jul 28, 2001 03:35 PM
