WHAT SIZE TIRE IS BEST FOR 16INCH ROTA GT3 ON 98 INTEGRA
Old Sep 9, 2006 | 09:18 PM
99delsol's Avatar
Default WHAT SIZE TIRE IS BEST FOR 16INCH ROTA GT3 ON 98 INTEGRA
I JUSTED ORDERED A SET OF 16INCH RED ROTA GT3 ,IM WONDERING WHAT SIZE TIRES IS BEST FOR IT,I HAVE A 98 GSR ITS PRETTY DROPPED,I HAVE NO IDEA HOW THE TIRE SIZE WORKS,IM SURE MANY OF YOU OUT THERE HAS A SET ON YOUR INTEGRA,I APPRECIATE YOUR INPUT.THANKS
Old Sep 9, 2006 | 11:41 PM
_Justus's Avatar
Default Re: WHAT SIZE TIRE IS BEST FOR 16INCH ROTA GT3 ON 98 INTEGRA (99delsol)
205/45/16
Old Sep 10, 2006 | 07:52 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: WHAT SIZE TIRE IS BEST FOR 16INCH ROTA GT3 ON 98 INTEGRA (tquick0910)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tquick0910 &raquo;</TD></TR><TR><TD CLASS="quote">205/45/16</TD></TR></TABLE>
Yup. You can use 205/45-16 or 215/45-16; either one will work. The 205 is probably the better bet on a lowered car, though, since it's less likely to rub.
If you're looking for summer tires (i.e. if you don't have to worry about snow) in 205/45-16, the Kumho Ecsta SPT is a great bargain, very good tire on dry pavement, awesome in rain (which is probably important where you live ), and a terrific bargain. In 205/45-16, it's $67 at the Tire Rack, which is $57 after you deduct the $40 rebate.
BTW, there's a button on your keyboard that you should get familar with...
Old Sep 10, 2006 | 08:31 AM
nick91civicsi's Avatar
i actually had the same question, i have some 16x7 rota c8's on my 94 teg and i have slightly rolled out fenders and i was wondering if i could go with 215/45/16 without them rubbing on the inner fender. i have 205's now and they work fine but i really want some wider tires since ill be boosted soon...
Old Sep 10, 2006 | 11:31 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: WHAT SIZE TIRE IS BEST FOR 16INCH ROTA GT3 ON 98 INTEGRA (nick91civicsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nick91civicsi &raquo;</TD></TR><TR><TD CLASS="quote">i actually had the same question, i have some 16x7 rota c8's on my 94 teg and i have slightly rolled out fenders and i was wondering if i could go with 215/45/16 without them rubbing on the inner fender. i have 205's now and they work fine but i really want some wider tires since ill be boosted soon...</TD></TR></TABLE>
Yes, you can use 215/45-16 and they will work fine.
The 10 mm difference in tread width won't make much difference in grip. However, you can get the Falken Azenis RT-615 in 215/45-16 (it doesn't come in 205/45) and it will give you much more traction on dry pavement than any other street tire. The traction is primarily due to the soft tire compound and the tread pattern, not the extra 10 mm of tread width.
Old Sep 10, 2006 | 04:53 PM
well i actually am planning on getting softer tires as well im looking at the new hankook rs2's that are supposed to be comparable to the falkens and iv actually heard from some people are actually better... i also forgot to mention that my car is dropped to the point where there is no fender gap but not actually tucking....
Old Sep 10, 2006 | 05:11 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (nick91civicsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nick91civicsi &raquo;</TD></TR><TR><TD CLASS="quote">iv actually heard from some people are actually better...</TD></TR></TABLE>
They're not. The Falken Azenis RT-615 is much stickier than the Hankook Ventus R-S2 Z212 (on dry pavement, of course). That's not only my opinion; most other people I've spoken with who have tried both have come to the same conclusion. Here, read this.
If you don't want to get the Azenis because you're afraid that a 215/45-16 tire might rub on your lowered car, then I would suggest getting the Goodyear F1 GS-D3 in 205/45-16, rather than the Hankooks. Better in the dry, better in the wet.
Old Oct 20, 2006 | 02:14 AM
leinadmiih00's Avatar
what tire size should i run if i have 15s and car is dumped?
Old Oct 20, 2006 | 07:13 AM
I Kick Squirrels's Avatar
I would go with a 205/45/16
Old Oct 23, 2006 | 11:07 PM
viet130i87's Avatar
umm not sure but i had 205/40/16 in my slips. and i put them on my friends integ. fit better then on my car.
Old Oct 23, 2006 | 11:26 PM
vtecsi00's Avatar
Default Re: WHAT SIZE TIRE IS BEST FOR 16INCH ROTA GT3 ON 98 INTEGRA (hondaguy717)
if you are running 15's your tire sizewould be a 195/55r15 or 205/50r15
Old Oct 24, 2006 | 03:08 PM
iheartintegras's Avatar
Default Re: WHAT SIZE TIRE IS BEST FOR 16INCH ROTA GT3 ON 98 INTEGRA (Hatch-N-si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch-N-si &raquo;</TD></TR><TR><TD CLASS="quote">I would go with a 205/45/16</TD></TR></TABLE>
Old Oct 26, 2006 | 09:14 PM
Dc2SacTo916's Avatar
Default SacTo 916
mines are 205/40/16
Old Oct 27, 2006 | 07:58 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: SacTo 916 (Dc2SacTo916)
205/40-16 is the right size for older Civics, but it's too small for an Integra (4.2 percent smaller outer diameter than stock). Get either 205/45-16 (0.8 percent smaller than stock) or 215/45-16 (0.7 percent larger than stock).
Old Nov 10, 2006 | 05:02 PM
ejmatzell's Avatar
Default Re: SacTo 916 (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">205/40-16 is the right size for older Civics, but it's too small for an Integra (4.2 percent smaller outer diameter than stock). Get either 205/45-16 (0.8 percent smaller than stock) or 215/45-16 (0.7 percent larger than stock).</TD></TR></TABLE>
what's the problem in having 205/40-16? i have 17's and want 16's and like the way 205/40 tires look... thanks
Old Nov 16, 2006 | 03:23 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: SacTo 916 (ejmatzell)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejmatzell &raquo;</TD></TR><TR><TD CLASS="quote">what's the problem in having 205/40-16?</TD></TR></TABLE>
It's too small in diameter (4.2 percent smaller than the stock size on your '98 Integra).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejmatzell &raquo;</TD></TR><TR><TD CLASS="quote">i have 17's and want 16's and like the way 205/40 tires look... thanks</TD></TR></TABLE>
205/40-17 is the correct 17-inch size for your car. But 205/40-16 is too small in diameter, much smaller than your stock tires.
Look at the outer diameter and how it compares to stock for each size, and you can see for yourself:
195/55-15: 23.44 inches (stock size)
205/45-16: 23.26 inches (-0.8 percent)
215/45-16: 23.62 inches (-0.7 percent)
205/40-17: 23.46 inches (+0.1 percent)
205/40-16: 22.46 inches (-4.2 percent) TOO SMALL!!!
Old Dec 11, 2006 | 06:10 AM
DeltaCharlie2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">what's the problem in having 205/40-16?</TD></TR></TABLE>
That's gonna look ghetto as hell. Teeny, tiny sidewalls are gay IMO.
Can someone please throw up some pics of the larger tire size in question? (215/45-16)
I am seriously considering buying the Azenis in this size but would like to see some pics of them on an integra. I've already seen a ton of pics of the 205/45-16.
Thanks!
NinjaJDMB18c
Apr 17, 2014 05:02 AM
mrchevez
Jan 12, 2011 10:19 PM
beaterman
Aug 17, 2005 05:45 PM
Chiller
Apr 12, 2005 08:55 AM
EKtypeRhaTcH
15
Sep 22, 2003 04:02 PM
