vtec help..
i just had a swap done on my 94 cx with the cx harness... will a jdm d15b run with out the vtec wired up? what about the o2 sensor?knock sensor? the shop says the car wont run unless i have the "harness for the vtec" which i think is b/s. the said the car starts then shuts down when it hits 1000 rpms.. i havent had a chance to go there and say anything, they basically b/s my mom when she went. (i was at work) if i dont wire up the four wire o2 sensor to the harness will it not run? or will it just throw a CEL? could the timing just be off? any help would be great thanks
Modified by xJDMCx at 10:11 PM 9/9/2006
Modified by xJDMCx at 10:33 PM 9/9/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGwhat!!! »</TD></TR><TR><TD CLASS="quote">im running my hatch without a o2 it runs fine except for a little rich and a cel</TD></TR></TABLE>
are you running the same setup? what ecu?
Kylegregg
12
Jul 26, 2018 06:43 PM
