Suspension & Brakes Theory, alignment, spring rates....
Intalled ground controls/konis and something is not right
Old Sep 9, 2006 | 07:18 PM
el_Presidente's Avatar
Default Intalled ground controls/konis and something is not right
thought i would tackle this suspension job myself to save $$$ and just something to do. i have an 04 accord coupe V6. i have installed the front Ground Control coilovers with koni shocks. went for a test drive and was goin fine for a while but now my car vibrates at any speed over 30ish. there also appears to be a noise but the odd thing is it seems to be coming from the rear, whch i had't touched yet. the best way i can describe it is as if some kind of object got stuck in between the tread on the tires. i checked but saw nothing. i don't intend to do anymore until tomorrow so i can't really check it any further. wanna resolve this before i get to the rear suspension. not enough light any thoughts?
it's my first suspension install. i read up as much as i could online tring to find all the info i could before i go do something i hadn't tried before. i wouldn't knock out the chance i made a mistake. any suggestions, hints or other help is greatly appreciated
Old Sep 10, 2006 | 07:24 PM
macDelli's Avatar
Default Re: Intalled ground controls/konis and something is not right (el_Presidente)
go back thru it and make sure you torque'd everything down... i mean not to doubt your work but i mean just start with the basics and move on from there
Old Sep 10, 2006 | 07:26 PM
PIC Performance's Avatar
Check your lugnuts, make sure they are torqued down properly.
Old Sep 10, 2006 | 08:40 PM
erikiksaz1's Avatar
Default Re: Intalled ground controls/konis and something is not right (PIC Performance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PIC Performance &raquo;</TD></TR><TR><TD CLASS="quote">Check your lugnuts, make sure they are torqued down properly.</TD></TR></TABLE>
Definitely check this. I think I've forgotten to torque down my lugs about three times now
Old Sep 11, 2006 | 11:07 AM
My95SlvrBlt's Avatar
Default Re: Intalled ground controls/konis and something is not right (erikiksaz1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by erikiksaz1 &raquo;</TD></TR><TR><TD CLASS="quote">
Definitely check this. I think I've forgotten to torque down my lugs about three times now </TD></TR></TABLE>
Only took me once, seems to be one of those things I never tend to forget
Old Sep 11, 2006 | 02:56 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Intalled ground controls/konis and something is not right (My95SlvrBlt)
Yea I've done that. Lost a lug nut or two. Oops.
You installed new codder pins right?
xfletcherxx
22
Nov 27, 2005 04:13 PM
justininhifi
Apr 29, 2003 08:12 PM
meanm3
Aug 22, 2002 09:00 PM
