EF Dash probs!!!!!!
Old Sep 9, 2006 | 05:27 PM
shiftjdm's Avatar
Default EF Dash probs!!!!!!
im putting the dash back in in this 90 EF, its all stock and everything, but were trying to understand why the CH light only comes when the headlights are turned on, and why nothing BUT the CH light is working, the heat gas sEAT BELT LIGHT dosent even turn on, for some odd reason after 20 mins of screwing around we got the low battery light on.......!!!!! weve checked fuses, batterys good, we've checked everything and taken out and put back in but its just going KRY - Z help!
Old Sep 9, 2006 | 05:48 PM
Suck my DX's Avatar
Default Re: EF Dash probs!!!!!! (imod)
are u using the correct year cluster?
Old Sep 9, 2006 | 05:56 PM
shiftjdm's Avatar
like I said, everythings stock, its the orig clus
Old Sep 9, 2006 | 07:19 PM
HondaHeddie's Avatar
Default Re: (imod)
you are missing a ground
Old Sep 9, 2006 | 07:22 PM
shiftjdm's Avatar
well there was a ground, and we put it on the metal frame supporting the whole radio, it was just there, and it did nothing, idk
Old Sep 11, 2006 | 07:12 AM
ls-v*2's Avatar
Default Re: (imod)
low battery light, child that is called the charging system light.
Old Sep 11, 2006 | 07:14 AM
y-49's Avatar
try to put that ground on the support that goes arround the stering column. and make sure all the plugs in the back of the cluster are pluged in good.
Old Sep 11, 2006 | 07:56 PM
shiftjdm's Avatar
ill try the ground around the column
Andrewzabomb
Feb 21, 2012 12:32 PM
attica
Aug 6, 2010 07:06 PM
Civic_kid_666
Dec 26, 2007 01:51 PM
