MPFI swap, STILL have a code 4.
Old Sep 9, 2006 | 05:24 PM
jhota's Avatar
Default MPFI swap, STILL have a code 4.
finished (yeah, right) swap. car wouldn't start, ecu blinking a code 4.
went through test procedure with multimeter - all circuts pass.
final step is "replace ecu with a known good ecu."
did that (thanks, Got_soy! ).
still no start, still code 4.
re-checked all wires/pins in plugs for correct location. what the hell am i missing, guys?
Old Sep 9, 2006 | 05:51 PM
Suck my DX's Avatar
Default Re: MPFI swap, STILL have a code 4. (jhota)
i was having the same problem with mine...turns out i had accidently spliced into b12 and b14 instead of b10 and b12...might not be your situation, but its definitely something to check...have you tried another distributor?
Old Sep 10, 2006 | 12:21 PM
jhota's Avatar
Default Re: MPFI swap, STILL have a code 4. (Suck my DX)
well, fixed the code 4.
still no start. no power at fuel pump or injector resistor box.
no power output on main relay. pulled out, checked solder connections, re-soldered. still no power output on main relay.
ordered new main relay, waiting. (should be here tomorrow).
Old Sep 10, 2006 | 01:16 PM
Suck my DX's Avatar
what was the problem?
Old Sep 10, 2006 | 02:29 PM
jhota's Avatar
one of the pins (b12) wasn't making a connection. to add insult to injury, it was one that was already in the plug - i didn't install it there; Honda did.
Old Sep 10, 2006 | 02:36 PM
Suck my DX's Avatar
are all your underdash connectors hooked up...i had to replace the harness in my 91 and them one i bought was from an 89...there were 5 connectors left over that had no counterpart...and for some reason my main relay was getting power to allthe pins except for the fuel pump...i wired the fuel pump directly to the battery and installed a switch...it works but i need to remember to turn it off everytime i shut off the car
mass-hatch
Jun 16, 2009 03:44 AM
1xfastxhatch
Dec 10, 2008 11:55 AM
Rease3
Mar 15, 2008 09:57 AM
EeeJayEight
28
Jul 25, 2004 12:07 AM
allm0torGSR
Apr 30, 2004 05:10 PM
