TPS question
Old Sep 9, 2006 | 03:10 PM
osaltyone's Avatar
Default TPS question
I tried searching, but can't get any results...
Can I use a TPS of a HF on my Si throttle body? I recently purchased a Si IM and it did not have the TPS.
Old Sep 9, 2006 | 03:50 PM
Tippyman's Avatar
Default Re: TPS question (osaltyone)
I believe you can. The DPFI TPS's go the opposite direction of the MPFI's. Because the HF is MPFI theoretically it should work.
So long as it bolts up the same give it a whirl. Make sure you program it correctly.
Old Sep 9, 2006 | 08:07 PM
osaltyone's Avatar
What do you mean when you say 'Make sure you program it correctly.'
Old Sep 9, 2006 | 08:25 PM
Tippyman's Avatar
Get a voltometer and measure the voltage at idle. hold on i'll try to find the thread for you.
Old Sep 9, 2006 | 08:26 PM
Tippyman's Avatar
Default Re: (Tippyman)
Code 7 - Throttle Position/Angle Sensor
TPS sensor input is used to determine when the throttle is:
Idle
Wide Open Throttle (WOT)
Rapid Movement
During these conditions the ECU makes changes to the injector Pulse Width (PW).
The PW is widen slightly when the throttle initially goes to idle. Within a few seconds the O2 sensor will correct the mixture.
Closed Throttle Input (under .5V), engine RPM is above 1100, engine is warm. The fuel injectors will be shut-off (used to conserve fuel). Peeps with A/F Ratio Meters will see this happen, when the gauge drops to full lean, or no reading at all.
When Wide Open Throttle is detected the PW is increased above normal fuel delivery. This is also known as "Open Loop" operation, when the ECU ignores the output from the O2 sensor.
With Rapid Throttle Opening the ECU is watching the TPS input voltage for rapid changes. A sudden rise in the voltage would mean the throttle was opened quickly. So the ECU would increase the PW momentarily. As soon as the MAP sensor senses the drop in vacuum, it will take over.
Testing - With the Key On, Engine Off hook up a voltmeter to the TPS. @ idle (closed throttle), voltage should be close to .5V and @ WOT (Wide Open Throttle) voltage should be 4.5V.
The best way to adjust the TPS voltage is @ idle (closed throttle). While Key On, Engine Off, hook up voltmeter between the yel/wht & grn/wht and observe reading. If it needs to be adjusted, loosen the TPS mounting and move the TPS until voltmeter reads close to .5V. The check engine light will let you know immediately whether you missed up or not.
TPS Sensor Wires:
1 Red/Blue
1 Green/White
1 Yellow/White
Old Sep 9, 2006 | 08:36 PM
EF Sedan Enthusiast's Avatar
Tippyman =
Old Sep 9, 2006 | 08:43 PM
Tippyman's Avatar
Default Re: (jdm_ef3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_ef3 &raquo;</TD></TR><TR><TD CLASS="quote">Tippyman = </TD></TR></TABLE>
Haha, i threw a code 7 today at the strip so I had to learn some ****.
nutball72
Nov 11, 2006 07:14 PM
hondaokie
Jan 14, 2005 01:28 PM
CrX-To-Tha-Max-v2.0
Nov 20, 2004 03:05 PM
snouka
Oct 15, 2004 02:02 PM
MOCrxHf
Nov 16, 2002 10:27 AM
