question about setting valves
Old Sep 9, 2006 | 03:07 PM
superstock2's Avatar
Default question about setting valves
ok so i just changed the headgasket on my d15b2 and have a question. i had the head resurfaced and they had to loosen all the valves. soo now the camshaft spins freely and i need to make sure i get the timing right. when i reinstalled the head i left the piston in cylinder 1 at top dead center. should i just put the cam gears "up" mark up and then reinstall the timing belt? any help is great!!
Old Sep 9, 2006 | 03:38 PM
george34's Avatar
Default Re: question about setting valves (superstock2)
The cam gear only goes on one way. There is a little notch in the cam and a dent like thing on the cam gear. If I understand what you are saying yeah you want the cam gear's up mark up. I think I set the head to TDC and then took the cam gear back off and but the timing belt on the cam gear and then installed the cam gear again.
I hope that helps you some.
Old Sep 9, 2006 | 09:53 PM
Default Re: question about setting valves (george34)
thanks fro the help man.... lets see the cam gear is on and the head is on the block which is at top dead center for number one. doesn't the up mark on the cam gear also mean the valves are in position for tdc on number 1? so theoreticaly if cylinder 1 is tdc and the cam gear is set to up then i should be ok?
Old Sep 10, 2006 | 12:54 AM
bump! i want ot get this bacl together but don't want to expletive something up!!
Old Sep 10, 2006 | 05:56 AM
george34's Avatar
Default Re: (superstock2)
If the cam gears up mark was up when you took the head off and you did not turn the crank pulleye then the cam gear's up mark should be up when you put the cam gear back on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superstock2 &raquo;</TD></TR><TR><TD CLASS="quote"> so theoreticaly if cylinder 1 is tdc and the cam gear is set to up then i should be ok?</TD></TR></TABLE>
Yes. Do a quick search for setting TDC so that you make sure you do it correct and that may clear up some of your questions.
89ED
18
Jun 22, 2018 03:38 AM
Ef4doorwagon
13
May 17, 2014 06:09 PM
jdm27ef
May 29, 2009 02:52 PM
Cuong-nutz
May 16, 2005 03:55 PM
adaml2nv
Dec 1, 2004 07:41 PM
