Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
rear shock bolt wont break loose?
Old Sep 9, 2006 | 02:26 PM
Sean DM's Avatar
Default rear shock bolt wont break loose?
the rear shock bolt that connects it to the frame wont break loose..
ive tryed EVERYTHING.
anyone have any ideas on gettin it out?
it spins a little bit but not alot and after you let go of it it goes back to where it was.
Old Sep 9, 2006 | 02:31 PM
Miracle's Avatar
Default Re: rear shock bolt wont break loose? (Sean DM)
Try shooting it with a burst of a thing called PB BLaster.
And make sure your ratchet is set to counter clcckwise.
Old Sep 9, 2006 | 06:11 PM
InanimateCarbonRod's Avatar
I've had it so the metal bushing inside the shock mount is corroded to the bolt. Try the loosener prescribed by Red. Also try a pneumatic impact wrench if you haven't already.
Old Sep 9, 2006 | 06:16 PM
Sean DM's Avatar
Default Re: rear shock bolt wont break loose? (InanimateCarbonRod)
yea i think thats what is going on beacause the bushing is moving when the bolt does too
thats what im using is impact rench and it barely moves it.
Old Sep 9, 2006 | 07:52 PM
I eventually used a 1/2" drive socket with a 3 foot breaker bar to get mine loose. It took a lot of effort but it eventually came loose.
Modified by InanimateCarbonRod at 1:04 AM 9/10/2006
Old Sep 10, 2006 | 08:13 AM
Sean DM's Avatar
im prolly going to end up going to a shop to get it broke loose and the last shock on.
i spent 6 hours on friday and 6 on saturday
and i got
front struts with coil overs
1 rear coil over with camber kit
and a camber kit on the other stock shock..
lower tie bar.
the strut bar wont fit..
looks like im going to have to do some remodling with it
Old Sep 10, 2006 | 09:01 AM
02_civic_4u's Avatar
192.193.216.151
I had the same problem. I just put a jack under my ratchet and jacked up on the end of my ratchet. It will break that bolt or it will break your ratchet if you have a cheap one. My tool wasnt even good name brand. I used my sears ratchet with my matco impact socket and it took care of that problem. Let me know what happens.
Old Sep 10, 2006 | 09:48 AM
Sean DM's Avatar
Default Re: rear shock bolt wont break loose? (02_civic_4u)
i tryed that and it spun a little bit but as soon as i lef the jack down the rench went back to place.
Old Sep 10, 2006 | 06:57 PM
Sean DM's Avatar
got it
finally
Old Sep 11, 2006 | 09:19 AM
192.193.216.151
How did you break it loose?
Old Sep 11, 2006 | 09:39 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sean DM &raquo;</TD></TR><TR><TD CLASS="quote">got it
finally</TD></TR></TABLE>
Glad to hear the good news.
I put anti-seize compound on the bolt when I reinstalled mine. Hopefully that will prevent it from freezing together next time.
Old Sep 11, 2006 | 10:01 AM
Newborn_'s Avatar
Grace Under Pressure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InanimateCarbonRod &raquo;</TD></TR><TR><TD CLASS="quote">
I put anti-seize compound on the bolt when I reinstalled mine. Hopefully that will prevent it from freezing together next time.</TD></TR></TABLE>
I sometimes use copper slip/copper grease (whatever you wanna call it) to stop things from seizing up in future. That also works well.
mondo375
Jun 27, 2007 05:57 AM
95 Gizzer
Jan 30, 2003 10:26 AM
Batoutahell
Oct 15, 2002 04:33 AM
94CivicSi
Mar 24, 2002 05:21 PM
