Calling all Prelude Master Mechanics......
Old Sep 9, 2006 | 12:52 PM
BoosterSH's Avatar
Default Calling all Prelude Master Mechanics......
Sup everyone, been a long time since ive been on here. Been real busy with work and other things. Unfortunately i will be visiting here ALOT more now because this past thursday i Hydrolocked my 98 SH. It wa raining like crazy and when i left work i hit about a foot of water. it was raining so hard i couldnt even see infront of me.
Anyways, after removing water from 2 cylinders and drying everything and installing new spark plugs i tried firing it up with no luck. I did a compression test and 2 cylinders read 25 and the other 2 were at 0. Nice.
I took off the valve cover and i could not tell if there is anydamage to the cams of valves, so my mind tells me either all the piston rings are gone, i warped the head, blew the head gasket or bent some rods. I will be removing the oil pan tommorow to check on that.
So depending on how much damage i have done and how much it will be to repair, i might just get a new engine instead of rebuilding this one. Im looking for a SH motor so i can swap it fast but if a Base motor/tranny or JDM Type-S motor tranny will bolt up to an SH frame and suspension i will swap in a base or Type-S.
Does anyone know if a Type S or Base motor will drop into an SH with out having to change out any suspension parts? I know i will have to get new driveshafts but is there any additional parts i will need to drop a Type-S or base in the SH Lude?
Thanks in advance everyone.
Chris
Old Sep 9, 2006 | 03:25 PM
fastlude69's Avatar
type s and sh have the same tranny so it would be a good swap
Old Sep 9, 2006 | 10:41 PM
k_lude's Avatar
Default Re: (fastlude69)
base motors are totally different from sh....it's the atts setup that differs it....the type s motor you would have to ask a mechanic....but it would make reasonable power..
remoer
Oct 14, 2011 11:06 AM
Superaison
Nov 4, 2009 06:57 AM
sawedoffcoupe
Sep 13, 2007 06:54 PM
Eucalyptus lude
Aug 16, 2007 01:30 AM
Revi
Sep 10, 2006 02:33 PM
