function7 lca's and st sway bar
ok, i have the function7 lcas on my crx. im about to order a st sway bar, how do i put the sway bar on?? do i need a new endlink or what. ive already searched and found one person that said they mounted the sway bar at the shock mount. i really have no idea what i should do since the lca does not have the tapped mount for the endlink like stock.
also, does the st sway bar come w/ the mounts and new endlinks or what.
Depends on which ST kit you order. There are some ST kits that are meant for the "non-Si" Civics (i.e. no sway bar originally). These attach to the bottom end of the rear shocks - a bag of parts is provided for this.
If you order the Si kits, you can use Honda OEM sway bar linkages, or our linkage kits if the linkage parts are not included.
-A
-A
JMelt4
18
Apr 30, 2007 07:43 PM
117
Suspension & Brakes
Apr 21, 2005 01:06 PM
katb16vo
22
Mar 25, 2004 03:29 PM
