help 86 crx si fuel problem
Old Sep 8, 2006 | 03:36 PM
R1SRUNS's Avatar
Default help 86 crx si fuel problem
getting fuel to rail but not through injectors????? did all checks in chilton manual, any ideas? is their a solinoid that shuts off the injectors that I can check. thanks Brett
Old Sep 8, 2006 | 03:56 PM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
Default Re: help 86 crx si fuel problem (R1SRUNS)
Things to check:
bad fuel pressure regulator
bad fuel pump/wiring
bad MAP sensor/wiring
bad ecu
I'm sure there are other things too
Sean DM
Jun 12, 2007 01:43 PM
hondacrx2
Apr 23, 2007 06:13 PM
91highryda
Feb 20, 2007 01:42 PM
INTEGRAMIKE
Dec 19, 2002 11:00 AM
