How do you take off the front bumper???
I know this is a noob question. But I can get my front bumper off. Im trying to change the bumper support. It's slightly bent due to a minor accident.
Thanks
Thanks
alright pretty simple....take off bumper lights....there are 4 bolts on each side 10mm...take those off....there are also i believe 4 phillips head screws under the bumper by the ground and a few by teh rad support/t bar. then there are two screws on each side of the wheel well on the inside. that should be it. you can take the whole bumper off by just removing the bolts under the bumper lights and the wheel well but you might as well take all of them off at the same time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmimportsusa »</TD></TR><TR><TD CLASS="quote">alright pretty simple....take off bumper lights....there are 4 bolts on each side 10mm...take those off....there are also i believe 4 phillips head screws under the bumper by the ground and a few by teh rad support/t bar. then there are two screws on each side of the wheel well on the inside. that should be it. you can take the whole bumper off by just removing the bolts under the bumper lights and the wheel well but you might as well take all of them off at the same time.</TD></TR></TABLE>
2 screws in each of the tire wells and 4 bolts (2 behind each light) and the entire bumper comes off. 1 Person can do this and when you are putting it back on its just as easy with one person as there are little hooks it goes into.
BlueShadow
18
Apr 29, 2007 11:39 AM
gsrpedro
Feb 28, 2007 08:23 PM
Keith P
12
Apr 25, 2005 04:17 PM
Ef Whore
Mar 12, 2003 01:35 PM
