About to get my car painted.. what lil stuff should i do / watch out for??
Old Sep 8, 2006 | 11:29 AM
J.nguyen's Avatar
Default About to get my car painted.. what lil stuff should i do / watch out for??
about to get my car painted and im worried about the little **** i have to do and stuff to make sure it turns out to be a good process without anything getting damaged or stolen..
so my car is a 95 Integra RS JDM frontend Turbocharged.. wondering what should i do when i drop my car off to get it painted (only getting outside painted ).. im hearing things like:
-remove front bumper
-remove tail lights?
-remove my advan rg I's and put it on doughnuts
-raise height of my car
-remove all my lip kit? and tell them to paint seperately
-tell them what parts to paint and what parts to paint black
-<ur opinions here>
im afraid of:
-theft or them not lockin my car
-them not knowing how to work my turbo timer and stuff or how they will drive my car
heres pic of it:
Modified by Jesse. at 12:03 AM 9/9/2006
Modified by Jesse. at 9:51 PM 9/18/2006
Old Sep 8, 2006 | 02:52 PM
J.nguyen's Avatar
Default Re: About to get my car painted.. what lil stuff should i do / watch out for?? (Jesse.)
anyone?
Old Sep 8, 2006 | 03:55 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jesse. &raquo;</TD></TR><TR><TD CLASS="quote">about to get my car painted and im worried about the little **** i have to do and stuff to make sure it turns out to be a good process without anything getting damaged or stolen..
-make bumper sag so that they can mask off the headlights so paint wont get on it
-remove door panels?
-remove my advan rg I's and put it on doughnuts?
-remove all my lip kit? and tell them to paint seperately?
-&lt;ur opinions here&gt;
im afraid of:
-overspray paint getting on my front mount intercooler
heres pic of it: </TD></TR></TABLE>
Pic isn't working.
Never head of that before. If its a decent shop, they should do a good enough job of taping off the headlights.
What for? they shouldn't be painting the inside, just the outside. Unless you specifically ask them to paint inside as well.
Shouldn't be necessary, but wouldn't hurt.
Definately. I have a painted tire from a bumper repair.
Shouldn't make a difference.
If you want the part under the lip painted, then you'll have to. Otherwise, they'll just paint it all together. Under the lip won't be painted, but under the lip isn't visible.
Multi-colored car?
Thats not really something you can worry about. its either safe or it isn't, but a door lock is hardly a protection measure.
Pull the wastegate spring, run without boost until you get it back.
Tape it off or remove it.
Old Sep 8, 2006 | 03:57 PM
-Championship-'s Avatar
76.169.175.137
Default Re: About to get my car painted.. what lil stuff should i do / watch out for?? (TunerN00b)
you want the brightest white on this car???....well it's your car but i would prefer jet black, or gunmetal color will be sex
Old Sep 8, 2006 | 08:48 PM
J.nguyen's Avatar
Default Re: About to get my car painted.. what lil stuff should i do / watch out for?? (CW_98gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">
Multi-colored car? </TD></TR></TABLE>
haha naa i meant like i want my grill black and my plastic piece around mirrors black and etc . not multi colored car lol.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tunern00b &raquo;</TD></TR><TR><TD CLASS="quote">
Tape it off or remove it.</TD></TR></TABLE>
wait u can do taht? and it will equal no boost?
and taping it off.. ic..
Old Sep 8, 2006 | 09:27 PM
davidluko's Avatar
You can just tape the intercooler off like all the other parts. Also, I think you mentioned something about this but make sure you tell them not to paint the front grill or the lower black part of the rear bumper (if it's 98+). It's just being sprayed white over white, right? If the mirrors are already white then you don't have to worry about this, but if they're some other color then remove the glass out of the side mirrors to paint all the way in the cracks. My brother's black car has yellow sticking out on the sides if you turn the mirrors far one way.
Old Sep 8, 2006 | 09:57 PM
J.nguyen's Avatar
Default Re: (Hatch_R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch_R &raquo;</TD></TR><TR><TD CLASS="quote">You can just tape the intercooler off like all the other parts. Also, I think you mentioned something about this but make sure you tell them not to paint the front grill or the lower black part of the rear bumper (if it's 98+). It's just being sprayed white over white, right? If the mirrors are already white then you don't have to worry about this, but if they're some other color then remove the glass out of the side mirrors to paint all the way in the cracks. My brother's black car has yellow sticking out on the sides if you turn the mirrors far one way. </TD></TR></TABLE>
oic. thanks 4 da info. should i just leave my bumper to sag a little bit? it wouldnt hurt anything right?
Old Sep 8, 2006 | 10:06 PM
davidluko's Avatar
Default Re: (Jesse.)
oic. thanks 4 da info. should i just leave my bumper to sag a little bit? it wouldnt hurt anything right?</TD></TR></TABLE>
I guess it wouldn't hurt anything, as long as the corners of the bumpers aren't covering the fender or covered up by the fender. It's not needed though, just extra work and worries.
Old Sep 8, 2006 | 10:56 PM
J.nguyen's Avatar
I guess it wouldn't hurt anything, as long as the corners of the bumpers aren't covering the fender or covered up by the fender. It's not needed though, just extra work and worries.</TD></TR></TABLE>
well when i remove my front bumper to cover the intercooler with tape. puttin it back on with zip ties and lil tabs and stuff be alot easier then acdtually using bolts and nuts and washers and using force / making sure it goes in perfectly /w no gap. but if i jus throw it on and ziptie, it will sag a lil bit
Old Sep 8, 2006 | 11:41 PM
honda genome
Guest
Posts: n/a
where are you getting it painted? If its a cheap place like maaco, 1day, earl shieb dont even waste your money, my paint job came out like **** and others did too. the quality of these shops just plain suck.
If you're afraid of them getting overspray on some parts you should simply do the masking yourself, believe me they dont give a **** who's car they are painting, they paint cars all day its their job so why do they care? ************* got overspray on my black leather interior, engine bay, windows...take out all the **** you can before you take it to the shop, it will pay off...
Old Sep 8, 2006 | 11:46 PM
J.nguyen's Avatar
Default Re: (N1 Wan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N1 Wan &raquo;</TD></TR><TR><TD CLASS="quote">where are you getting it painted? If its a cheap place like maaco, 1day, earl shieb dont even waste your money, my paint job came out like **** and others did too. the quality of these shops just plain suck.
If you're afraid of them getting overspray on some parts you should simply do the masking yourself, believe me they dont give a **** who's car they are painting, they paint cars all day its their job so why do they care? ************* got overspray on my black leather interior, engine bay, windows...take out all the **** you can before you take it to the shop, it will pay off...</TD></TR></TABLE>
dang ic i was also thinking the same "believe me they dont give a **** who's car they are painting, they paint cars all day its their job so why do they care?"
yeah.. plannin to take to one day or carcoa... dont know any good shops that r reputable in SD...
Old Sep 9, 2006 | 07:59 PM
tofu man's Avatar
The car looks awesome as-is. btw what lip's and sides are those?
about them knowing how to drive your car. i would tell them not to drive it. they dont need to drive it to paint it. they can push the damn car wherever it needs to go.
Old Sep 9, 2006 | 08:08 PM
mike9571's Avatar
Default Re: (cw.tech)
Painting a really low car is a pain but they will just have to deal with it.
If i were you I would put the doughnuts on it just incase of some overspray. Also it will discourage them to want to beat on the car.
I work at a dealership body shop and all of the techs including myself will beat on a car in the parking lot if its quick.haha
Yes you should remove tail lamps.
As for the frontmount just point it out to them that you dont want any overspray on it.
im afraid of:
heres pic of it:
Modified by Jesse. at 12:03 AM 9/9/2006</TD></TR></TABLE>
Old Sep 9, 2006 | 08:12 PM
mike9571's Avatar
Default Re: (mike9571)
Depending on how much you want to spend tell them to remove front/rear bumper cover, fenders, lip kit to paint off car. It might cost a little extra but its worth it.
Old Sep 9, 2006 | 09:42 PM
J.nguyen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike9571 &raquo;</TD></TR><TR><TD CLASS="quote">Depending on how much you want to spend tell them to remove front/rear bumper cover, fenders, lip kit to paint off car. It might cost a little extra but its worth it.</TD></TR></TABLE>
why is painting it off the car (rear and fornt bumper) diff then painting it on the car? i can understand lip kit but why bumpers? how about if i just come into the place with my rear and front bumpers already off and i just give it to them like that?
Old Sep 9, 2006 | 09:55 PM
7andaswitchblade's Avatar
seriously, if youre worried about half the things you listed in your first post, DO NOT GET YOUR CAR PAINTED. Even if you only spend $100 getting your car painted at a 1 day place, you wasted $100. Factory paint, no matter how bad it is, is gonna be better than the best maaco job i've ever seen.
if you take your car to a REAL paint shop, they're not going to get overspray on your headlights, they're not gonna beat your car, you won't have to worry about your wheels, or your intercooler.
you should be spending around $2500 for a decent 'outside only' paint job.. i dont care if john smith got a great paint job from maaco or joe whatever found a legit place that will do it for $1000, you get what you pay for. Those 1 day places dont give a **** about you or your car, the paint they use is a joke, their prep work is a joke, they do the shittiest tape jobs ive ever seen, they dont buff anything out, and most of the time their jobs are orange peel nightmares, unless you get luck and get a guy who actually has some real education.
cheap paint jobs
especialy on nice cars (like yours)
Old Sep 9, 2006 | 09:56 PM
honda genome
Guest
Posts: n/a
take off all lights or mask them up yourself...mask up the black parts you dont want painted (inside bumper,etc), raise up car to stock height, take out interior if you are doing door jams, make sure sides of the hood underneath are covered up or they will get overspray into the engine bay which is very very hard to clean once paint settles. I wouldnt recommend getting it done at maaco, your best bet would be that shop right by thai cafe, i forget the name, or try the one day paint, i saw a paint job from them on typermans cars and tehy were decent, nothing to brag about, but decent...If i were you though I would really save up and spend the extra money over 1G for a paint job cause you might not be happy with the results, like what happned w/ my 4dr GSR i had to sell it bc the paint was ****, I shouldve paid 400 more at a better shop and have a really nice paint job, but I wanted to save....in the end, you get what you pay for.
Old Sep 9, 2006 | 11:27 PM
Leo C's Avatar
Night Owl
Default Re: (Honda Genome)
If it were me I would take off the front + rear bumper, sideskirts, mirrors, tail lights, emblems and wheels. But hey, I'm picky.
Old Sep 10, 2006 | 02:18 AM
J.nguyen's Avatar
Default Re: (shutupnskate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7andaswitchblade &raquo;</TD></TR><TR><TD CLASS="quote">seriously, if youre worried about half the things you listed in your first post, DO NOT GET YOUR CAR PAINTED. Even if you only spend $100 getting your car painted at a 1 day place, you wasted $100. Factory paint, no matter how bad it is, is gonna be better than the best maaco job i've ever seen.
cheap paint jobs
especialy on nice cars (like yours)</TD></TR></TABLE>
dang.. cause theres alot of reasons why i want a paint job rather then just change to a brighter white. 1st off car was originally red, and guy who sold me car sold it with a big *** key mark on passenger side, + a lip kit that when i removed showed alot of ugly marks / scartches / etc. also i just traded away my CF hatch for extra cash for a black one so i need to paint that also /w shaving trunk holes. so im guessin to my knowledge this will be the 3rd time it gets painted after its oem color. but your right about it though.. if only i had 2500 to spend on paint job.. my budget is at most 1,400$ thats if i get lucky and sell some stuff im tryin to sell on HT here.. but i agree with what ur sayin, thats what i think of too sometimes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Genome &raquo;</TD></TR><TR><TD CLASS="quote">I wouldnt recommend getting it done at maaco, your best bet would be that shop right by thai cafe, i forget the name, or try the one day paint, i saw a paint job from them on typermans cars and tehy were decent, nothing to brag about, but decent...If i were you though I would really save up and spend the extra money over 1G for a paint job cause you might not be happy with the results, like what happned w/ my 4dr GSR i had to sell it bc the paint was ****, I shouldve paid 400 more at a better shop and have a really nice paint job, but I wanted to save....in the end, you get what you pay for.</TD></TR></TABLE>
yeah my brothers EK got painted at maaco, i didnt like it at all.. i saw typerman2001s 400$ paintjob on the integ. look good for that price, but i want something that last for the long run. im not hearing so much good from 1 day.. sometimes good, sometimes bad.. im thinking about either carcoa (i know they arnt GREAT, but decent i guess cause my last car got painted there and it was ok.. juss alot of overspray and orange peel.. but hey i had that car for like over a year and drove it over 300-400 miles a week on average and paint look like it was clean )
or this one shop my friend recommended me to , miramar auto body or something place that works on ferraris and stuff.. cost about 1,500$ but he got his car painted there and it turned out good.
Old Sep 10, 2006 | 06:53 AM
mike9571's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jesse. &raquo;</TD></TR><TR><TD CLASS="quote">why is painting it off the car (rear and fornt bumper) diff then painting it on the car? i can understand lip kit but why bumpers? how about if i just come into the place with my rear and front bumpers already off and i just give it to them like that?</TD></TR></TABLE>
Yea of course if you already have the parts taken off it wont cost you any extra. But if you dont have the parts already off than thats extra time they have to spend. More time is more money.
Old Sep 10, 2006 | 09:42 AM
davidluko's Avatar
Yea of course if you already have the parts taken off it wont cost you any extra. But if you dont have the parts already off than thats extra time they have to spend. More time is more money.</TD></TR></TABLE>
I've heard from people on H-T that if there's any kind of metallic pieces or pearl or any flakes like that in the paint, that you want to paint the car with all the body panels already on so that the flakes flow the same way and match or something like that, but that you don't have to worry about that if you don't have any flakes.
Old Sep 10, 2006 | 12:14 PM
J.nguyen's Avatar
yeah ic.. so if i do this. i wont need to Mask off my Front mount intercooler b/c they wont need to paint front part of my car b/c my front bumper is off already??
Old Sep 10, 2006 | 12:51 PM
mike9571's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jesse. &raquo;</TD></TR><TR><TD CLASS="quote">yeah ic.. so if i do this. i wont need to Mask off my Front mount intercooler b/c they wont need to paint front part of my car b/c my front bumper is off already??</TD></TR></TABLE>
Thats correct they will cover it up.
Did they already give you a price? Also do you know what kind of paint they will be using?
Old Sep 10, 2006 | 01:07 PM
J.nguyen's Avatar
Did they already give you a price? Also do you know what kind of paint they will be using?</TD></TR></TABLE>
na not yet. havnt got quoted. just been lookin around for good shops first. gonna get a quote or something sometime this week.
Old Sep 18, 2006 | 08:52 PM
J.nguyen's Avatar
so got quoted. 710$ out the door for an integrated paint job. and 1800$ for base / clear /w buff and wetsand.. hmm big *** jump.. too bad nothing in between.. =\
