weird Chugging and pinging.........
so i just bought a 93 4 door and ...
when i drive it Pings like crazy and it chugs and sputters if you get on it past 1/4 throttle
its kind of an intermitant chug although it happens every time you get on it its kinda sparatic getting worse as you go up the rpm range
any ideas anyone ????
I did the timing on it
its has a new fuel filter have not pulled the injectors yet to see if they are clogged
has a new coil (supposedly) i need to check the cap and rotor
the plugs are ok
the plugs are ok
hrm.. i know my car did this twice... once when the tps was goofed up and once when i put straight leaded gas in it by mistake
It could be a number of things but they should throw a CEL.
O2 Sensor
Clogged Cat
Injector
Plugs or wires..
.It could be a number of things but they should throw a CEL.
O2 Sensor
Clogged Cat
Injector
Plugs or wires..
Mrbigaznboi
May 5, 2009 01:09 PM
