header install
Old Sep 8, 2006 | 10:35 AM
B16b-EJ8's Avatar
Default header install
is it mandatory to change the gasket when installing a header? or is it just recomended?
Old Sep 8, 2006 | 10:46 AM
Luserkid's Avatar
Default Re: header install (B16b-EJ8)
Which gasket? If the gasket isnt broke dont fix it.
doublejz's Avatar
Its not mandatory... its sorta like head bolts.. When you crank them down their strectched.. when you crimp the gasket theres no reclamping and resealing. just replace it... do it right the first time and dont worry, its not like they're expensive
Old Sep 8, 2006 | 10:59 AM
-Gary-'s Avatar
Default Re: header install (doublejz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublejz &raquo;</TD></TR><TR><TD CLASS="quote">Its not mandatory... its sorta like head bolts.. When you crank them down their strectched.. when you crimp the gasket theres no reclamping and resealing. just replace it... do it right the first time and dont worry, its not like they're expensive</TD></TR></TABLE>
X2
Old Sep 8, 2006 | 11:07 AM
B16b-EJ8's Avatar
Figured as much...the gaskets cheap ill just grab one
VTecLude1994
Jun 27, 2005 10:04 AM
EtherGhost
Sep 9, 2004 07:44 AM
VTECdTypS
Jul 17, 2004 11:29 AM
LAKER HATER
May 15, 2004 09:01 AM
rudjfio85
Sep 14, 2003 02:02 PM
