washed car now i get a solid CEL
Old Sep 8, 2006 | 10:32 AM
TallKyle's Avatar
Default washed car now i get a solid CEL
I already have searched...
I decided to wash my car around the time it was getting dark out, which was about 730 pm. I went to leave my house at like 9 pm and the car started for about 4 seconds and died. Went to restart it and it would run for a second and die. I noticed i was throwing a solid CEL. I threw in another good ecu and it did the same thing. I opened my hood and water was on like 2 connectors. I took my air gun and blew every single connector out and checked all of the grounds. Soo i called it a night and thought there was water somewhere. So i let it bake in the sun for about 6 hours today. Went to try it and it did the same thing. Today i checked all the fuses, wiring, connections, etc. I also swaped in another good ecu and still nothing.
Anyone have any ideas?
Old Sep 8, 2006 | 10:38 AM
si90rex's Avatar
Default Re: washed car now i get a solid CEL (TallKyle)
why don't u tell us what the code it throwing is it just might help
Old Sep 8, 2006 | 10:39 AM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si90rex &raquo;</TD></TR><TR><TD CLASS="quote">why don't u tell us what the code it throwing is it just might help </TD></TR></TABLE>
"a solid CEL" - meaning no code.
anything noticably cooked in the ECU?
I'm guessing this is in your EF, and it's boosted so it's chipped and tuned.
Did you swap the chip to the new ECU?
I'v had chips get messed up for no reason before, simply reflashing them fixed the issue.
Old Sep 8, 2006 | 10:41 AM
TallKyle's Avatar
Default Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">
I'v had chips get messed up for no reason before, simply reflashing them fixed the issue.</TD></TR></TABLE>
yes my car.. everything looks fine. i swaped the ecu with 3 other PM6 just virgin ones to see if the solid LED would go away. no luck.
Old Sep 8, 2006 | 10:45 AM
jedubz's Avatar
Default Re: washed car now i get a solid CEL (si90rex)
Before making smartass responses read the TITLE of the post? SOLID CEL is basically a code for bad ecu.
Kyle seems like you took all the neccesary steps to drying everything off but your ECU is still getting a bad signal, could one of the connectors on the harness possibly have rusted or been disconnected? Which 2 connectors did you say had water on them? It may take a long time but I would reccommend disconnecting and reconnecting the plugs on your wiring harness possibly cleaning them off if one appears to be rusted. Whens the last time the car ran normally?
Old Sep 8, 2006 | 10:50 AM
TallKyle's Avatar
Default Re: washed car now i get a solid CEL (jedubz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jedubz &raquo;</TD></TR><TR><TD CLASS="quote">
Kyle seems like you took all the neccesary steps to drying everything off but your ECU is still getting a bad signal, could one of the connectors on the harness possibly have rusted or been disconnected? Which 2 connectors did you say had water on them? It may take a long time but I would reccommend disconnecting and reconnecting the plugs on your wiring harness possibly cleaning them off if one appears to be rusted. Whens the last time the car ran normally?</TD></TR></TABLE>
I took apart every connector and blew out every one with the air gun. My map sensor was all covered with water and so was the big white plug that connects the main harness to the engine harness. Everything is dry now. I didn't drive the car at all yesterday but the day before it was running fine on 20 psi. Ran fine for about 1500 miles now. I never usually wash my car cuz i never get it dirty. 2nd time i washed my car since i owned it.
I disconected my map sensor and reset the ecu and it still throws the solid cel.
Old Sep 8, 2006 | 11:00 AM
ILcrxsi1's Avatar
I tell doctors what to do
I would go back to that main connector for the engine harness again, lots of pins in there lots of **** to go wrong.
Still have the injector resistor box? I don't know if that thing could fvck something up like this but I'm just tossing out ideas.
Old Sep 8, 2006 | 11:05 AM
TallKyle's Avatar
Default Re: washed car now i get a solid CEL (ILcrxsi1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILcrxsi1 &raquo;</TD></TR><TR><TD CLASS="quote">I would go back to that main connector for the engine harness again, lots of pins in there lots of **** to go wrong.
Still have the injector resistor box? I don't know if that thing could fvck something up like this but I'm just tossing out ideas.</TD></TR></TABLE>
yea ima go out right now to look at it all close.
Yea i still ahve the resistor box. I unplugged it and reset the ECU and it still threw the solid CEL right away. so thats not it.
Old Sep 8, 2006 | 11:09 AM
ILcrxsi1's Avatar
Even though it has nothing to do with the cel I would check fuel pump etc. anything in the fuel system. Fuel delivery problems usually cause a car to start and then die.
Old Sep 8, 2006 | 11:13 AM
TallKyle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILcrxsi1 &raquo;</TD></TR><TR><TD CLASS="quote">Even though it has nothing to do with the cel I would check fuel pump etc. anything in the fuel system. Fuel delivery problems usually cause a car to start and then die.</TD></TR></TABLE>
I changed the main relay and it was fine. Fuel pump kicks on like normal. Since its throwing the solid CEL thats why its not running. Something is wrong
Old Sep 8, 2006 | 11:39 AM
SwapedEX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TallKyle &raquo;</TD></TR><TR><TD CLASS="quote">I changed the main relay and it was fine. Fuel pump kicks on like normal. Since its throwing the solid CEL thats why its not running. Something is wrong </TD></TR></TABLE> i agree... check the pump.. and make sure your injectors are pulsing..
Old Sep 8, 2006 | 11:45 AM
TallKyle's Avatar
Default Re: washed car now i get a solid CEL (SwapedEX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwapedEX &raquo;</TD></TR><TR><TD CLASS="quote"> i agree... check the pump.. and make sure your injectors are pulsing..</TD></TR></TABLE>
you're an idiot. Has nothing to do with that.
Anyway while i was checking voltage on things i picked up my 2.5 bar map and it was really hot. I have been trying to figure this out with redzcstandardhatch on the phone and he things the wires are melted for the map sensor. Ima go run new wires right now.
Old Sep 8, 2006 | 11:58 AM
TallKyle's Avatar
well that wasn't it either. I ran out of ideas
Old Sep 8, 2006 | 12:07 PM
ILcrxsi1's Avatar
shorted wire where main harness goes through firewall?
Old Sep 8, 2006 | 12:09 PM
TallKyle's Avatar
yea i think it is a short somewhere. When i first started the car last night it ran for 10 seconds pefect and then it just died. Soo after that is when i had the problem
Old Sep 8, 2006 | 12:16 PM
ILcrxsi1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TallKyle &raquo;</TD></TR><TR><TD CLASS="quote">yea i think it is a short somewhere. When i first started the car last night it ran for 10 seconds pefect and then it just died. Soo after that is when i had the problem</TD></TR></TABLE>sounds about right https://honda-tech.com/zerothread?id=1512394
Old Sep 8, 2006 | 12:20 PM
TallKyle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILcrxsi1 &raquo;</TD></TR><TR><TD CLASS="quote">sounds about right https://honda-tech.com/zerothread?id=1512394</TD></TR></TABLE>
mine only ran for the first time i tried to start it.
Old Sep 8, 2006 | 12:23 PM
ILcrxsi1's Avatar
time to bust out the ohm meter and start checking wires
Old Sep 8, 2006 | 04:16 PM
TallKyle's Avatar
well i pulled out my whole engine harness and it was fine. put it back in and with a stock ecu and it was fine. put in the chipped ecu and it fucked up. so i guess it was a bad ecu all along but its werid that the same stock ecu was doing it easier
hooray my new ecu is on its way and i think i can still go to dyno day tomorrow. Thanks for the help fella's.
Old Sep 8, 2006 | 08:37 PM
ILcrxsi1's Avatar
I have a pm6 I would have sold to you for like $5
Old Sep 8, 2006 | 09:02 PM
danmdevries's Avatar
Damn TK that really sucks bigtime. Good luck with the dyno pulls, I'm interested to see if the cam can beat Adam's huge new fmic :-p
Old Sep 8, 2006 | 10:43 PM
TallKyle's Avatar
Default Re: washed car now i get a solid CEL (danmdevries)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danmdevries &raquo;</TD></TR><TR><TD CLASS="quote">Damn TK that really sucks bigtime. Good luck with the dyno pulls, I'm interested to see if the cam can beat Adam's huge new fmic :-p</TD></TR></TABLE>
i'll find out tomorrow. I just put on the performer X intake with LS TB and the car feels better. I hope to put over 300 tomorrow
Old Sep 9, 2006 | 09:10 AM
ILcrxsi1's Avatar
my girlfriend just called my and said "I think I just saw that tall kid you bought your alternator from driving down 95th street, does he have a black car?"
Old Sep 9, 2006 | 10:08 AM
TallKyle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILcrxsi1 &raquo;</TD></TR><TR><TD CLASS="quote">my girlfriend just called my and said "I think I just saw that tall kid you bought your alternator from driving down 95th street, does he have a black car?"</TD></TR></TABLE>
yep. that was me going to the dyno.
Old Sep 9, 2006 | 02:23 PM
redzcstandardhatch's Avatar
something different
check it out yo.
http://www.ef-honda.com/main/viewtopic.php?t=23365
Charlie Moua
Sep 29, 2014 04:37 AM
jneely
Feb 29, 2008 08:53 PM
ls19integra95
Feb 26, 2008 07:16 PM
PokeyD16Z
Jun 6, 2004 06:08 PM
