dohc zc parts list
I have a 89 crx and an 89 hatch. I am planning on putting a zc in both. The question i wanted to know is where can i get parts for the motor. If i wanted to change the motor mounts, timing belt, water pump, or spark plugs can i get this from Auto Zone, Kragen, Napa, or the Honda dealer? Also the 89 hatch is auto can i put the zc in it and still use the same trans?
This should help out with the parts http://www.thezcr.com/forums/s...12262 . If you are replacing any gaskets I would get genuine honda. You may be able to cut a few corners with other parts, but as always you get that for which you pay.
