OBD conversion
Ok I know this has been covered a lot, but even when I searched archive content, I couldnt find a straight answer.
I have OBD-0 b16a motor in civ. si (1990)
I am doing an OBD-0 to OBD-1 and then Turboing that.
WHAT EXACTLY DO I NEED FOR THE OBD1 CONVERSION
someone find me a list or make me one, or add to mine
OBD1 ECU
OBD1 Dizzy
OBD1 Injectors
02 sensor (4 wire) do I need one or 2?
And what harnesses do I need? http://www.rywire.com has a few harnesses
should I get theses?
OBD0 - 1 Dizzy adapter-----They dont sell these seperate, anywhere to get one?
OBD0 - 1 Conversion harness (ECU)
Do I need anymore than those 2?
And also which ECUs would work best? P28?
-aXhatch
I ahve spent a good few hours looking but cant get a straight answer, please someone help me out.
OBD1 ECU
OBD1 Dizzy
OBD1 Injectors
-aXhatch
Your Right on the money man
1 four wire o2 sensor
b16 Obd1 Dist
You can keep your current injectors just leave your resistor box installed
Obd 0-1 conversion harness
And you dont even need dist jumpers, you can wire the obd1 plugs right onto your current mpfi harness basically color for color
b16 Obd1 Dist
So then COMPLETE LIST WOULD BE
1-4 wire o2 sensor
1-B16 OBD1 Dizzy
Keep my injectors installed.
1-OBD0 to 1 ECU Conversion Harness.
Do you know where I can get wireing for my plugs?
And also, I am turboing, so could I get bigger, OBD1 injectors, and TAKE OUT the resistor box? Like order for an OBD1 b16a and the uninstall my resistor, or would my best bet be to get OBD0 compliant injectors that are bigger?
Thanks for the help dude.
1-4 wire o2 sensor
1-B16 OBD1 Dizzy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aXhatch »</TD></TR><TR><TD CLASS="quote">Hey can I get a Dizzy from a 1994 Del Sol VTEC?
was the 1994 del sol VTEC (b16) an OBD1 or OBD2 car?</TD></TR></TABLE>
You can use any dizzy from the 92-95 GSR or the 95-95 Del Sol Vtec. I got mine from the "Distributor King" off Ebay and only paid $200.00 shipped! it came with a three year gaurantee as well! just search Ebay or Google for the "Distributor King" and you should find the number, I had it but can't find it at the moment. by the way, my dizzy has worked great for 2 1/2 years so far so I HIGHLY recommend them.
jacoblytle
Engine Management and Tuning
Jun 25, 2014 07:56 AM
