car alarm messd up?
Old Sep 8, 2006 | 08:59 AM
sol_1's Avatar
Default car alarm messd up?
My brother's civic hatchback has an alarm and he left the lights on one night and when he charged the battery the alarm didn't work anymore. Now the battery gets drained al;l the time for no apparent reason. Does anyone know what it can be or anyone with expirience on car alarms can come and check it out. Thanks in advance.
Old Sep 8, 2006 | 09:21 AM
fcm's Avatar
fcm
Old Fart
Default Re: car alarm messd up? (sol_1)
A batt. that has gone completely dead, may have warped its plates and they can short out so the batt. can no longer hold a charge, to test make sure it's charged, [will start the car] then disconnect the batt. overnight, reconnect in the morning and try and start the car, if the car starts it's a good bet the batt. is OK, and the problem is probably the alarm, disconnect the alarm, [unplug it overnight] and see if the batt. is still OK in the morning, you can also test for a draw on the batt. with a multimeter, also most shops the do batt./alt. will do a load/grav. check on your car for free, only takes a min. 94
Old Sep 12, 2006 | 11:17 AM
sol_1's Avatar
The battery wasn't the problem, it was a good battery. Would anybody else know what the problem can be.
Thanks fcm.
Old Sep 12, 2006 | 02:59 PM
fcm's Avatar
fcm
Old Fart
Default Re: (sol_1)
What is the make and model of the alarm, does it still not work?
Old Sep 12, 2006 | 05:18 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
If you are local I can check it out for you. Follow the steps that fcm gave to to trouble shoot it. Post your results.
Chris1954
May 23, 2017 09:26 PM
JBB93Coupe
14
Jun 16, 2009 02:11 PM
ntoxicatedtigah
11
May 4, 2009 10:54 AM
Dr. Willy
Audio / Security / Video
38
Jan 18, 2009 10:50 PM
