zealautowerks.com CR calcualtor
Old Sep 8, 2006 | 07:12 AM
jaydem_ekizzle's Avatar
Default zealautowerks.com CR calcualtor
I was bored so i was reading up on what the about cr will be of my gsr and i put thi info in
block b18c
head b16b
crank b18c
piston pct
connecting rod eagle
headgasket 2 layer
head milling .0
rpm 9400
and my static was 13.4:1 as was the effective
Old Sep 8, 2006 | 08:05 AM
DJ_NeX's Avatar
Default Re: zealautowerks.com CR calcualtor (jaydem_ekizzle)
did you input your elevation? If you're above sea level your effective CR will be lower.
SCR is your compression @ sea level.
Z0831xiz
May 24, 2015 06:02 AM
unknow
Sep 14, 2010 05:49 AM
thunderboy
Jul 13, 2010 09:38 AM
lVlemphizStylez
Sep 20, 2006 10:17 AM
pinoyk20
Jul 9, 2006 01:31 PM
